SeanT4x4
- Oct 2, 2013
- 185
So yesterday after work I was bouncing on the front end to check for bump steer, after reading about that on here (different problem). I noticed a couple drops of brake fluid leaked out of the brake line where it meets the caliper. I had done a disk brake conversion about two months ago and figured those copper washers hadn't smashed enough for it to seal properly. Figured I'd give it a little more torque... bad idea. I sheared the head off and leaked brake fluid all over the garage. Two question, whats the best way to get the rest of that banjo bolt out? (I've never done it before) Its a chevy disk brake conversion from Toms, what do I tell the guy at O'reileys as far as make and model so he can get me the right banjo bolts?
