Shifting issues
CO-Bronco69
Basalt, CO
I'm tyrying to troubleshoot why the dual shifting linkages inside the engine compartment of my 1969 Bronco don't seem to both be responding to my attempts to shift them from the shifting arm on my steering column. For example, I can't use the shifter arm to put the vehicle in reverse, but can do so by manually manipulating the linkeage rod itself. Conversely, I can seemingly use the shifter arm to find first gear. This is a manual three on the tree. Thanks!
jckkys
Have you checked the shift tube in the steering column to see if the tab at the bottom has come off?
Since the first and reverse gears are on the same arm at the base of the column, I'm curious what it's doing exactly. When you try reverse, does the shift lever on the column inside just stop dead like it ran into a block? Or does it move upward a full sweep, but does not move the arm under the hood?
C
CO-Bronco69
Basalt, CO
The best way that I can attempt to describe it is that when I move the shifter on the steering column I can only get the linkage rod closest to the firewall to respond. I’m not entirely sure which gears that arm controls. Other than that the second arm closer to the front of the car does not respond at all to any corresponding movements that I try with the shifting arm inside the vehicle. Likewise the shifter arm in the vehicle doesn’t move when I manually adjust that same forward shifter linkage in the engine compartment. I’m guessing that that forward linkage is what controls reverse because I’ve been able to manually adjust that rod to put the bronco into reverse but I can’t get it to go into reverse using the shifter inside the vehicle.
Sound like a broken shift tube then. Or a disconnected arm at the lower end of the column.
Your Reverse and First gears are on the same arm/lever. So the fact that you can get it into first, and you can see the arm come up when you move the lever inside the cab say that your first/reverse section is working. Why it won't go into reverse then, is the question.
But that might be related to a buggered shift tube.
The fact that you don't see any action at all on the 2/3 arm is equally bad news. Time for a tear-down maybe.
At the same time though, get underneath (parking brake on) and make sure that when your shift lever is in Neutral that both of your transmission shift arms are in their Neutral positions. Then, make sure that you can move one arm fully into all three positions when the other arm is in neutral. The try the other way around.
The shift detents inside the gearbox keep one arm from trying to get into gear when the other arm is in another gear. So no shifting at cross purposes.
But if one arm is slightly out of place, the other one might be unable to move.
It really sounds like a shift tube issue, but that's not the only thing that can be at work here.
Unfortunately very few shift tubes are available anymore. We had a decent supply about four or five years ago, but apparently they were in great need because they disappeared quickly. There are different versions depending on which column you have, so they are specific.
But the good news is that they can often be fixed relatively easily.
Good luck.
