rzorrilla2348
- Feb 20, 2017
- 15
Hey folks, I need your help...
Last night, I did a routine change of my transmission fluid on my C4 automatic transmission on my 76". I took the opportunity to also change the screen filter inside while I was at it.
After letting the gasket/sealant dry overnight, I filled the pan with "type f" ...about 4 quarts and it started right up and measured just right. However, when I went to test drive, the trans appears to be stuck in 3rd gear. I can use the shift lever to go into 1st and 2nd...but in D, it goes back to 3rd.
Did I miss something here? I know there's one spring and plunger in the screen...which I thought to have re-installed correctly. I have the plunger first, spring pushing against the filter... Did I get that wrong and now causing this? Cheers
