Shocks! Help!
Georgelas
Vienna
I am trying to find a good shock for my truck. We want absolutely the best handling shock available. we will drive the truck off road 30% of the time but not seriously. It is more a show truck.
I want my wife to be able to drive safely and it to handle well. Here is what I have: (74 Bronco)
1. 4.5 inch wild horses suspensin lift.
2. Helwig anti sway bars front and rear.
3. Extreme shock hoops.
4. Delphi steering box
5. Saginaw pump.
6. Hydroboost.
77 front end (Dana 44)
9 inch rear.
I called a shock distributor and asked what the best shock is for this truck. Cost is not an issue, this is my dream truck. The shop recommended King 3.0 triple bypass shocks or the comparable Fox shock. One on each corner. If this is the best set up then we will get it. However I am not sure that i understand the benefit of full travel valving on a primarily street truck. I seem to get a different recommendation from everyone I ask.
Cheers
Aaron
asinor
Tulsa, OK
King and Fox shocks are overkill for your needs unless you want the bling for the shows. There is no benefit of external resivoirs or multi bypass tuneability for the street.
Lennardlector
Virginia Beach
Everyone will have their own opinion on shocks and what is "comfortable" to them. Even though its impossible to find someone with your exact setup, go to a local meet or contact people on this board and go for a ride and see what YOU like.
bronc50
5. Saginaw pump.
6. Hydroboost.
9 inch rear.
Cheers
Aaron
How did you get the hellwig front sway bar to fit with the extreme hoops?????got any pics of the setup or of your truck
bronconut73
Bilsteins, Ranco RS 9000's, Duff 70/30's.
They are all great and reasonably priced compared to King or Fox.
RS 9000 will allow you to adjust them to your liking. About $100 each
Duff 70/30 shocks are "in theory" what is supposed to go on a suspension like ours (probably not the best ride though). About $40 each
Bilsteins 51 or 71 series are kind of idiot proof. No need to adjust they just seem "right". Their price point can vary widely but fall just below to just above the RS 9000. They probably are the superior shock at this price point.
rguest3
x10 on Bilstein shocks.
5100s on 4 different Broncos now. Bilsteins on a 2 Jeeps and also 2 Ford Super Dutys.
You may never purchase another brand again.
xcntrk
NOVA
I like the Bilstiens because you can get them valved very specific to your application. Also note in the rear with leaf springs there's not as much need for granular compression/rebound control so don't waste a bunch of money for high-end shocks in the back.
G
Georgelas
Vienna
I think I am going to go with the Bilstein 7100. I really appreciate the advice. What is crazy is the guy at Down South Motorsports said absolutely the best way to go is the king Triple bypass. Has anyone worked with these guys?
Re the helwigs. I am not running the from shock on the extreme shock hoops.
Cheers
bronconut73
The Kings are a better shock. And a $160,000 Ferrari is better than a $60,000 Vette.
Unfortunately, in our hobby, you can buy way more technology than you really need.
It is easy to over spend if you're not careful.
It is all a matter of what you need.
The Kings would be "great" for some hardcore running like washboard at 60+ mph but for us regular guys they are likely overkill. I bet those triple by pass Kings would look "bad ass" though!
xcntrk
NOVA
Cheers
I'll tell you what, buy the King's if you're sold on them and I'll trade you my Bilsteins direct swap! ;D
bronc50
Cheers
I understand no front shock but does the bar not still hit the hoop...both hell wig and wh told me it would not work because the bar hits the hoop
G
Georgelas
Vienna
Hmm. I had better check that we are talking about the same hoops. I am only running the extreme hoop up front. The hoops go on this week so let me double check. I have all of the parts.
bronc50
I saw. Will be having a chat with Mark in the AM!
Maybe if we get enough people on side with this hell wig will not give the end bends a 90 degree turn and instead do 95 degree as to leave the ear ends apart 1/2 inch a side!!!!
sicaz66
san diego
Cheers
Just picked up my king shocks from Sonny at d.s.m.s. getting my work done at the building next door. Way cool guy and knows his stuff.:cool:
