Show me your dash.
4x4x289
here's mine
hawkgt
Leesburg, VA
Today's project
It just so happens I finished mine up today. I wanted to keep it as stock looking as possible but I wanted to be able to use the glovebox with a roll cage. I just took out the ash tray, moved the speaker grill and glovebox over, and added in some metal on the right side. I also removed the fuel selector switch since I am only running one tank.
Projp
These are 2 1/16 guages
blackjack
San Diego
dash
I have not put very much time into my dash to make it look pretty.
BuiltFordTough
Louisville
how are you monuting the aftermarket radio? i have the hole cut but what is going to keep the radio in there. Do those little tabs on the mount do the job?
jate
Salt Lake City
Here are a couple pics of my dash. It is out getting painted and the aluminum dash will be painted to match the exterior.
rob wilson
Flagstaff, AZ
Getting close to done on mine. Used 2 5/8" gauges from Autometer. Still need to mount the heater controls in the holes. Open space above that is where I'm mounting a GPS. Speedo is on the left side of the steering column. Used JBL Marine speakers on either end. Also installed the Autometer Tri-Alert. It turns on a buzzer if my Oil Pressure or Gas Level get to low or if the Water Temp gets to high.
Pasadena, TX
Hope you don't mind me chimming in on this thread but it fits a question I have.
I am replacing my vacuum wipers with electric wipers on my '67. I bought the entire system from Tom's Bronco Parts. Where is the stock location of the wiper switch on the dash. I am hoping someone can tell me where it is located on one of the pictures posted in this thread.
msweb
I really like your switch console! Is home made or did you get it from somewhere? What's in the front center of it - a remote for a radio?
Are your guages angled towards the driver and if so, what did you use to do so??
Thanks,
Mike
eds66bronco
Essex, Vermont
here is the dash cover plate i just finished. billet aluminum sheet to cover all the hack jobs done by po. i based it off the stock 77 dash and used the police package guages that came with the crown vic for the motor swap. also got matching rocker switches from waytek to match the one for the front locker.
PS
Sebastopol, CA
Here's mine, before during and after. (Now the wiring under the dash has been addressed and I've installed my new Momo steering wheel...)
rob wilson
Flagstaff, AZ
Mike,
Home made. 1/2" square tubing covered with 18 gauge. Top panel is 1/8". hinged at the rear for access to the Ron Francis fuse box inside. Switches are all marine rockers that are waterproof. Whole thing is powder coated so should last.
Yep, it's a marine remote for a Kenwood head unit. Completely waterproof. Planned on mounting the head unit inside the glove box but it's looking like I may not have the depth I would need for that. Remote provides control over power, volume, channel, track etc.
Autometer makes the inserts to angle the gauges. Only angled the 4 furtherest from the driver (on the right). Works really well.
Flash69
Southwest Va
My wiper switch is on a 69. I dont know if it is the same as a 67. It is the black knob beside the radio hole. HTH.
bmcqueen
Corinth, MS
I went with a simple layout...moved the speedo and added vintage air to the center...wiper and light knobs on the left side of the wheel.
