smoother ride
bzod
Just purchased my first bronco (1977, uncut, hdtop, all original). I'm a total newbie. I want to make it more of a cruiser so I'd like a "smoother" ride. Any advice/suggestions? I am going to give it a suspension lift.
gjrock
Anacortes,WA
You are going to get a lot of different suggestions.I like my 3 1/2" wild horses lift with 33x12.50 tires.I like my Rancho 9000's.The WH lift is the rock crawler one,It is nice and soft.If you get a kit it will come with all new poly bushings.welcome aboard!
BroncoMark
Irvine CA
If you're getting a suspension lift, and want a smooth ride, look for a 10 or 11 leaf pack set for the rear. I hear Cage leafs are good too, and they are 8 or 9 leafs. Either way, stay away from the 5 leaf packs, add a leafs, and blocks. The thinner leaf packs offer better flex, so they won't ride like a semi. Also, get a good set of coil springs up front. All of the Bronco vendors sell good ones. Stay away from Superlift, Rancho, or anything you might find at your 4Wheel superstore. Finally, get good shocks. Bilsteins are real nice.
josimps2
First off you should post some pics for everyone to check out the new ride. I vote for you to keep it stock. Get a complete stock suspension kit from one of the quality vendors, put new body mounts on the truck, get a modern set of seats, and upgrade to power steering if you don't already have it. Get a set of 30x9.50's street tires and run low tire pressure for a decent ride. Just my vote.
If you don't like this idea you can always go with a 2" body lift and put 34.950 Super Swamper TSLs underneath it. Should be just what you are looking for. ;)
73azbronco
Billstein shocks, best bang for buck in the handling department.
Mherriford
Oregon City, OR
I just installed a new cage 3.5 inch lift, the difference in ride quality, between my new suspension and the old is amazing, it is like a different truck, I have to learn to drive it all over again
B
bzod
smooth ride
Thanks for the feedback. I'll be posting some pics. Keep the suggestions coming.
70_Steve
Old Guy
If you buy suspension components or a complete system from any of the vendors on this board, they will be designed more for articulation than just lift. This means softer springs. As was already said, the more leaves in the rear springs, the softer the ride. For a cruiser, you may want to chose a progressive rate coil for the front, rather than a linear rate. The shocks will probably make a huge difference in the ride quality. Bilsteins are great shocks, but since ride quality is very subjective and personal, you may want to consider an adjustable shock, like the Rancho 9000X 9-way adjustable shocks. I bought the Rancho 9000 5-way adjustables 10 years ago, and they work fine for me.
cgbexec
Naples, FL
I would go uncut. 30" to 31" narrow tires that fit inside the rear. New suspension system (stock or 2.5" with soft springs). Sway-bars front and rear. Go either overdrive automatic or NV3550 manual trans. That would be a sweet ride!
Doleauto
Good luck with your Bronco. If you want a smoother ride, I also suggest staying with all stock suspension. I bought a 74 Bronco from Wilmington Ford, in Mass back in 74. You cannot imagine what a nice vehicle it was new. It drove like a Lincoln TownCar, got 19 miles to the gallon with 302, and went just about any place I wanted to go. Personally, I think there is nothing worse than a Bronco that is hacked and jacked. I know, I made everybody mad. The 74 had the "big tire" option when I bought it, it had L78-15 snows on it. My 71 I bought with a plow, used, in 80, had F78-15's, and would push snow over the roof of the cab. All the new vehicles from the factory today have too big a tire on them, and in NH, where we have had 12 feet of snow this year, THEY are the ones upside down in the snow banks. If you are going off road, and think you need to, then jack er up, if you want a fantastic driving and riding vehicle, leave er stock.
Dan's73
My experience has been that the new suspension systems all ride & perform better than the stock EB suspensions. I'm primarily talking about the springs & shocks, but most of the other upgrade/replacement components certainly help too. I've had 4 EBs & worked on many, many others. I've replaced the suspensions on all but one using everything from the F150 coils & re-arched leafs (DON"T do this one) to the all-out mega-systems from the EB vendors.
My current '73 was bone stock when I got it and everything was in excellent condition, but I wanted to lift it. I was amazed at how much better it rode & handled when I put on the Wild Horses 3.5" lift with the Rock Crawler coils & 11 leaf rear packs. I didn't go huge for tires, just 32x11.50 BFGs. Speedbumps were still noticeable but no longer bone jarring, and, in general, every aspect of the ride & handling had improved over stock. The same may hold true for the new "stock replacement" springs (no experience with these), but you said you were planning to lift it, so there you go!
73bronco
I went from stock to WH 3.5" and the difference was amazing! My last bronco had a superlift 3.5" on it and it was worse than stock. I now have cage 5.5" front coils and cage 14" travel front shocks with a custom 4-link out back with rancho rs5000 adjustable shocks and the difference from the WH 3.5" kit to my current system was improved yet again. It is the nicest riding bronco I have been in and I have been in quite a few! Definitely get a kit from one of the bronco venders as they are DESIGNED for the old broncos. Superlift and rancho and whoever else that makes kits for every other vehicle out there do not care how the vehicle rides, they only care that they sell, sell, sell!
