snap rings on ball joints
mraine
Newbie
I am replacing the ball joints on a 77. The bottom ball joint works fine, the top seats properly but the knuckle covers the snap ring slot. If I grind it down, I need to grind the bottom surface of the part of the knuckle that supports the ball joint.
See the pic, the single blue arrow is ok but the backside with the double blue arrow needs about 1/8th ground down.
If I can get an angle grinder in there, I am about 70% sure I can grind it down enough to get the snap ring on. Do I need to? Can I go without a snap ring on the top ball joint? Is the knuckle strong enough to grind an 1/8th off?
WILDHORSES
USA
Do not grind the knuckle. Bronco only uses the lower snap ring. What you have is 100% normal. Trust me I even went and jumped under my 77 to double check. Your not the first one to run into this and it does seem weird.
Jim
Timmy390
Conway, AR
Old thread. It's a common issue.
https://classicbroncos.com/forums/showthread.php?t=214037
Thread talks about the ball joint press tool at the parts stores not being adequate and the need for a additional tool kit specifically for 4x4 that has an adapter that goes on the C clamp/installer that pushes the ball joint further into the knuckle?
I used NAPA prem ball joints on 79 bronco knuckles with a 20 ton HF press. No issues with the snap rings
Tim
Seventee
In the sticks of MT
Tim
Interesting enough I have '78 knuckles without snap rings on the top joints, even though the groove is visible. Same thing on my '79 F-150. It's been a long time so I don't remember for sure, but I am wondering if they came with snap rings for the top? If so, not sure why I wouldn't have installed them...?:?
Either way I don't think it's an issue.
