Whatever plugs the engine would normally use.
Gap is based on ignition used and a little on the compression ratio. A more powerful ignition you run something in the lower 0.040" range, breaker point ignition it is in the upper 0.020" range. If there is a lot of cylinder pressure you are trying to pass the spark through, a little less gap. Not so much cylinder pressure you go a little larger.
