Solenoid or ignition switch
GRN_MEANIE
Bronco wouldn't stop running till I pulled the I-term wire from the solenoid. If i leave it disconected it shuts off like it should. If it's connected then it doesn't shut off. It's a centech harness and has been working fine for 4-5 years.
Viperwolf1
electron whisperer
Sounds like a bad solenoid to me. The "I" should only get current from the battery side when the solenoid is engaged. Sounds like it has an internal permanent short. Does the motor start with the "I" unplugged?
GRN_MEANIE
GRN_MEANIE
Yeah, it acts normal with the "I" unplugged. With the key in the off position there are not any volts on that terminal. So what's making it not turn off
Kyle.malone
Norman, OK
I don't have a clue, but just to let you know.. The I term wire is just a loop in the system and goes to the three wire plug in the engine compartment and is with the electric choke and other wires. I talked to Centech and was told that with aftermarket goodies, that Ididn't eve need it hooked up. If you have aftermarket parts, you might want to give Centech a call and see.
Steve83
OK That's good. If it'll still exhibit this symptom, crank it up, turn the key off, and measure voltage on ALL the relay terminals (or wires) while it's running with all the wires still connected to the relay. Use a stickpin to pierce the wires if you can't get to the posts, but don't let the pin touch anything else.
GRN_MEANIE
GRN_MEANIE
1 off it shuts off with the I wire connected now for some reason. Bronco running I have 14v on (-) side of solenoid, 14v on I term, nothing on start, 12v on (+) side of solenoid. Isn't the I term only powered on start though?
Viperwolf1
electron whisperer
"I" is powered by solenoid only when solenoid is on. It could be getting power from the other end of the wire though when not in START, ignition power to the coil.
Steve83
So the problem has completely disappeared?
Something's not right... First: there is no (-) side of the starter relay. There's a large BATT (12V) terminal; a large terminal for the heavy wire to the starter; a small S terminal (LB/R) from the ig.sw.; and a small I terminal to the ignition system. The relay's mounting base is grounded. Did you take those readings with the key ON or OFF? With the key ON, engine running, & all wires connected normally, you should have battery voltage on BATT and I (only 2 terminals).
Voltage backfeeds to it from the ignition system, and since there's no current flowing, it comes up to full battery voltage. Disconnect it from the relay & check voltage on the relay's I terminal with the engine running - it should instantly drop to 0 (open circuit). The wire should stay at battery voltage whenever the key is in RUN.
GRN_MEANIE
GRN_MEANIE
Yeah it's back to working right...
By (-) your right I meant to say the side going to the starter.
I didn't think about it back feeding. Will check when I get home.
