Hi All,
After installing a ZF tranny in my rig, my speedo cable was too short, and needed a new one.
Old configuration: 1973 sport, 302, C4 Transmission, 70" speedo cable, black speedo gear.
New configuration: 1973 Sport, 302, ZF Transmission, 82" speedo cable, black speedo gear. (the speedo gear needs to be changed to accommodate my 33" tires and 4.11 gears - a future task)
The adapter that connects the Dana 20 transfer case to the ZF Transmission is 2.25" thick from surface to surface. You can see my install at http://www.kokes.net/bronco/zf_trans.htm
The Napa part number for the 82" speedometer cable is: 615-1646. It was a direct bolt-in replacement and no modifications were needed, and the length was adequate without having any excess. The ONLY difference was the attachment nut on the speedometer side. The old 70" cable had a hex nut, and the new 82" cable had a textured finger-tighten nut.
Hope this helps someone.
-Ben
-Ben
