ntsqd
heratic car camper
To address this I made a special tool from a spare spindle nut, some exhaust tube, an o-ring, a chunk of plate and a grease zerk. O-ring is a size that butts against the end of the spindle. Tube and plate are welded to the spindle nut to form a "cup" of sorts. Several short pieces of tube were cut and made smaller OD to create a ledge for the o-ring. Zerk is in the center of the plate.You don't necessarily have to pack the inside of the seal area, but the spindle itself and certainly the bearing area should be packed.
The more grease the better at keeping moisture out in the long term. A bunch will splooge out when you install the spindle, but that can then be used to re-pack the bearings and/or the hub's inner cavity surfaces.
Screw the tool on far enough for the o-ring to seal on the end of the spindle, attach grease gun, and listen for grease to splorch out of the back of the spindle. You may need to use a bar to keep the stub axle from backing out of the rear of the stub spindle under pressure from pumping the grease in.
Main reason that I made this was so that if I suspect water entry all I need to do is remove the locking hub and I can use the tool and the grease gun to flush any contaminates out the far side of the stub spindle.
