split dash...
Madgyver
Bronco Madman
I did a simple cut on a couple of dashes to make things easy... I don't like removing front cage to get the dash out.
Speedrdr
Legend in my own mind
Paris, MS
Looks great, but does your glove box door open? I don’t plan on removing the dash once the cage goes in.
Randy
bronco italiano
Love it Mad!!!!
The fact that the steering wheel can be installed before the dash is great.
Thank you!!!
At first glance, that masked off bronco door in the background makes it look like you’re painting a Dodge Daytona or Plymouth Super Bird in the shop!😁
Madgyver
Madgyver
Bronco Madman
Nice AAW fuse panel. Is that part of a full harness, or did you buy just the fuse panel alone?
Actually, thinking about some of the previous pictures, I'd say it was a full harness! :)
Madgyver
Madgyver
Bronco Madman
it was a full AAW harness
snick
Great idea on cutting the dash in that location. I’m now seriously considering it. Question: From the pics it looks like the cut above the column (or the column opening in the dash) is not centered, looks like it’s offset to the driver side a little. Is it just the angle of the pic or was there a reason you didn’t center it. Would hate to cut my dash dead center of the column opening and then find out later that it needed to be offset for some reason. Is the bottom cut dead center? My bronco dash is torn apart right now so I can’t really look myself.
