Spot welds???
stout22
Athens, AL
What would be the best method to remove a windshield frame for re-use? Those darn things have about a gazillion spot welds that are hard to get to:mad:
sellitall
Malvern, Pennsylva
The cowl panels are even better. Chock full of spot welds. I used every configuration of tools to get those panels off. Still have a nice scar left from the last cowl section I replaced.
bec
Mount Pleasant
Jeff's has them for 23 bucks i found some on ebay for 5 there on the way we will see what happens but i was just using a hammer and chisel the air hammers to fast and it tore some of the steel i was going to keep LOL
allenfahey
That's why bodymen weaken the welds with the cut off wheen and wide 3" wheel first.
'69 Bronco
Southern California
On panels that I have access to on both sides I use a spot weld cutter and then weld the hole that the pilot bit left. But I don't cut all the way through if I can help it. In those instances it's a bit more welding to cover the hole but no openings are left. What I'm left with that way is a panel that I can spot weld back on that looks just like the original. Yes grinding is faster and that's why shops do it because time is money but I'll spend a little more time on it and enjoy the build.
bec
Mount Pleasant
just to follow up the 1 from ebay was junk it lasted 3 spots before braking i went to a auto body supply house and got a BLAIR spot weld cutter for 21 bucks and its way better then the chisel air hammer or what ever it has change able tips its the bees knees
BroncoJAK
Cut many a weld with the Blair rotabroaches too. Center needle just doesn't hold it in place good enough for me. It's why I prefer the spot weld cutters over the hole cutters like the rotabroach. Center punch or dimple the welds with a 1/8" bit to keep the cutter centered. You can replace the needles too.
Bigjam
Dallas
I second the Briar rotobroach bits, won't buy the cheap ones anymore. Usually drill a small pilot hole to eliminate the bit walking.
bec
Mount Pleasant
i dont know how you guys were useing it but i put the center in the center and got it drill up to full speed and then puswhed down on it and it didnt walk around on me but when i had it pushed all the way in and pulled the trigger it would walk or may be i was luckey LOL;D
