Start help needed
MSREDNECK
Hello guys, I went out to start the bronco and it will turn over and crank but will die as soon as I let go of the key. What would cause this all of a sudden?
Slowleak
Georgia
Could be a bad switch or resistor wire. Turn the switch to “on” and check for power in the red/green wire at the coil. If there is no power there, then check the same wire at the switch to determine if it is the wire, or the switch itself. The resistor in that wire can burn up if the key is left on while the engine is not running....
M
MSREDNECK
I am getting 12.1 volts at the coil with switch in on position, it drops to 10.5 while cranking but stays constant. Could something have failed in my distributor?
B RON CO
Statesville, NC
Hi, it sounds like it is cranking over but not starting.
You have to make sure the engine is getting gas in the carb and spark out of the distributor to the spark plugs.
Take of the air cleaner and you should smell gas.
Get a $10 spark tester for the tool box.
Or for now hold the spark plug wire just over the plug on the distributor cap and look for spark when a helper cranks it over.
Good luck
SteveL
Huge chevy guy
Hawthorne ca
Was it running ok before and just won't start? Or did it die and won't start back up? If the later it could be sheer pin on the distributor gear. If the oil pump goes south that pin will snap. It will crank and crank but not turn over and run.
pipeline010
starter
sounds like the wiring is fine, but to be absolutely sure you could try a jump line straight from your positive coil to your battery. start it, if it dies again you've ruled out any starter issues.
of course, if it keeps running you'll have to have a way to pull your jump line. key off won't stop it.
fuel
truck off squirt some fuel into the bowls. anything going in? if no, check fuel lines. if yes, start truck again and crank throttle before loosing key, note any changes in engine behavior before dying.
spark
check your cables make sure nothing is loose.
triracer67
Stock distributor, or does it have pertonix? Drop Under 12 volts and it won’t stay running.
M
MSREDNECK
Update
I parked it about two weeks ago and go out today and this is happening.
Fuel is good, it has fitech fuel injection and it is priming like always and putting a squirt in the engine.
Appears the coil is good after testing (ohm test) but no spark at plugs. The coil is a msd blaster 2 with a duraspark 2. I plan to check the wires and ohm the distributor wires next, unless you guys think I should do something else.
