Starter coming on when revving engine? Any ideas?
langester
MASTER OF MADNESS
Let me start by saying this is not a Bronco (sorry didn't know who else to ask).
I am working on an 83 f 150 with a 351w. It starts fine and runs at an idle, if I rev the motor up the starter tries to engage grinding like crazy. I replaced the solenoid, ignition switch and tumbler mechanism, and am at a loss at this point. I replaced the solenoid first , no help thats when I replaced the other parts. Everything looks to be in good shape on the column, wires look good. Is it possible the bendix is loose and allowing it to start and then slips out and catches the flex plate ?
Anyone ever come across this or have any ideas. Any help would be greatly appreciated! Thanks in advance!
75MIKE
NE Washington
Have you opened the inspection plate on the back of the bell housing and checked to see if the flex plate is loose or bent?
langester
langester
MASTER OF MADNESS
I haven't checked that yet. I was going to crawl underneath tomorrow and pull the starter and check out the flex plate. This is a really goofy problem, never seen anything like it.
I appreciate the reply!
Thanks!
B RON CO
Statesville, NC
Hi, when did it start doing this? Has anyone changed the starter recently? Did you know there are 2 different starters, auto and stick are different.
I would just get the correct starter and go from there.
Good luck
ared77
Since it is a "goofy" problem, I'd connect a meter to the post of solenoid that runs to starter. A voltmeter with the red lead on the 2nd large post and the black lead on a good metal ground. Then watch it when you start the truck, see 12 volts? You should, then no voltage after you've released the key. Now keep watching meter as you rev up engine. 12 volts reappear? If not go on to pull starter, look for bent flexplate, etc.
If you DO see 12 volts when revving, it may be because of some flexing of the wiring harness causing a 12 volt situation on the 1st small post of the solenoid. There should be no voltage there unless the key is turned to "start" position. If there is I'd pull the connector off that small post, after the engine is started, and rev it up. If all is good you have a short circuit (or something) causing an erroneous voltage to cause the solenoid to spin starter...at the wrong time!
Wiring is a long shot, but easy to rule out by just looking at a meter. Good luck!
Norm
langester
langester
MASTER OF MADNESS
Thanks for the replies. The starter has not been changed as far as I know. This is my Nephews truck. I was doing rust repair and took it for a spin after I was done, that is when the problem started. My Brother bought the truck a few months ago, he only put 50 or so miles on it before he brought it to me on a trailer, so no telling what the history is on it. I will go test the solenoid wiring and see what happens.
Thanks for the help, I will keep you posted when I find something out.
sykanr0ng
When the engine revs it will twist in the mounts.
Does that make a wire come into contact?
langester
langester
MASTER OF MADNESS
Thanks for the reply, I think I figured it out. I should have crawled under it yesterday. So it ends up not being the starter at all or the flex plate. I crawled under and looked and there is a small pipe hooked to the exhaust (1 inch diameter) for the emissions (which were taken out before we got the truck. You cant see the damn thing unless you are underneath, it comes off the top of the pipe and it hidden quite well.
Basically they cut the pipe and pinched the end off so it would not leak and left it hanging there. It is hooked to the y pipe which looks like a Cat, it is attached with a clamp, so it will swivel. When I revved up the motor the pipe would swivel over and hit the starter and start making noise, it sounded like the starter was trying to engage.
I secured the pipe and will button up the rest of the truck and road test it but I am 99% sure that was the problem.
My dumbass fault for assuming it was the starter! Typical day in my life, nothing new here.
You gotta laugh about it or else start crying, not sure which is worse!
Attac
langester
You have another letter that should be at the plumbing shop by tues or so
Chuck
langester
langester
MASTER OF MADNESS
Thanks for the heads up Chuck. I will keep an eye out for it.
Thanks!
