Starter screeching on startup
Joe473
What year is that flexplate from. I did some starter research recently and at some point in the 90s I think the auto and manual starters become equal part numbers. Just don't know of the changed flywheels or flexplates.
Is it possible late model flexplates use the manual starter recesses drive?
Sent from my SM-G900V using Tapatalk
I think that info you got was some recently corrected mistakes in the parts store's computers Joe.
According to my books, they remained two distinctly different starter housings all the way through at least '96, but as recently as a month ago my local parts place showed only the one part number for both in their computer.
When I called them yesterday they reported that the computer now showed two different numbers for manual and automatic.
It's still possible that there was that change to a common starter and ring gear spacing, but it wasn't in the typical Ford cars and trucks up to the point that my books cover. So Mustangs and Pickups/Broncos shared the same two different PMGR starters. Differing only by transmission applications.
There was a third, 3-bolt design some have seen on things like Exploders and such I think, but I've used the same earlier 2-bolt designs on Explorer/4R70W combos with no trouble.
Hopefully all the stores will get updated stuff now too. And hopefully that was the only change too! Otherwise we have to keep dealing with the usual uh-ohs every time we open another parts store box!
JohnJohn
JohnJohn
Richmond
Joe,
I am currently running a new Wild Horses 50 ounce 164 tooth flexplate just for my late model 5.0 and C4 combo.
JohnJohn
JohnJohn
Richmond
I FIXED IT!!!!!!!!!!!!!!!
I pulled the working starter from my 77 and tried it in my 70 and it started up nice and quiet and normal.
That means the 4 remanufactured made in China starters vrom Autozone were the problem. I guess I will try a new starter until I find one that works.
So many lost hours..... and many beers
Justafordguy
You really should get a later style gear reduction starter. Way better than the old style like you have now. They have a built in solenoid and use much less amps from your battery. I think the Autozone PN is DL3205S.
Joe473
Paul, Thanks for clearing that up. It didn't make sense to me at the time and even rock auto was showing same part numbers for auto/manual after 92 or 93. I ordered a brand new bosch for a 91 f250 5.8 manual which had a picture that clearly showed the recessed drive for manual trans.
And yes the later starters have advantages in smaller size and less draw.
JohnJohn
JohnJohn
Richmond
For the benefit of others the Advance Auto Parts # 3180SN was the solution to my screeching issue. I am now running this in both Broncos with no issues. It's a new starter but it blows away the 4 remanufactured ones I went through from Autozone that were all junk.
cw
Try mean green reduction starter. works great for my application.
I've actually got one on order for my rig. I've always liked them, but kind of shied away from the price. But been working on a '73 for a customer (full Painless re-wire) and his Mean Green is a wicked strong little dude and sounds very capable every time we've messed with it.
It's an interesting design. Not sure what it's originally out of, but it's super compact and has some real juice.
Hopefully I'll have the same results in mine.
