Last couple posts lead towards timing issues due to flames coming out the carb...this should only happen when you have ignition spark (intake valve open) coming up out of the cylinder into the manifold/carb... back your timing off to a safe 8deg. (when you get it running or just ever so gently retard the timing w/o it running).
Now, flooding issue... the carb might be too big for optimum performance BUT it is not so big that your engine won't run and run dang good actually. We used to run carbs that were too big ALL the time back in the muscle car days... no issues starting, running, never fouling plugs- ever! We just didn't know better back then!
So, why are you fouling plugs? It takes a lot of fuel to do this on a V-8 as the fuel must be literally pouring out of the carb to enter into the intake and make it's way to all the plugs-not just a couple- enough to foul them... PUMPING the daylights out of the carb trying to start it when NOT cranking it is usually the biggest culprit.
Pull all your plugs again, clean/dry them off. Then BEFORE putting the plugs back in, you need to get the fuel out of the cylinders...
CAREFUL here... DISCLAIMER HERE...
You MUST disconnect your ignition system to eliminate ANY chance of spark ANYWHERE... even the starter can cause enough spark to ignite all the potential fuel in the cylinders... yes, seen it happen-not some YouTube video either, but real time.
So, with the plugs out, the ignition coil/system totally disconnected , crank the engine over to potentially shoot gas out the cylinders. yeah, seen this happen too- real time.
Put plugs in, fire it up...
I think your carb is leaking or boiling over when you shut it off (maybe) OR when you go to start it up after it's been sitting (like your post #29 I think), you are flooding it.
You're in the south, not too cold... shouldn't need much if any choke but you do need a richer idle/choke circuit to help it start when cold...maybe a couple throttle pumps AS YOU CRANK IT over....
After 2 days of your Bronco not running, open the hood, pull the air filter, and see if there is fuel squirting out of the accelator pump jets when looking into the carb while moving the throttle...I'll bet nothing happens because the carb has lost/leaked all the gas out of the bowls...
Next, have someone inside with the key crank the engine over doing NOTHING else for almost 30 seconds. Perform the same accelerator pump test to see if the fuel pump (manual-not electric) has now had a chance to fill the float bowl.
If not, crank it again for 20-30 seconds then repeat the visual throttle linkage movement to look for gas squirting into the carb.... this will help narrow down some possible issues...
Good luck
