Steering Box Removal + Install
Ok, so what did the trick? Different hose? Different adapter? Future users want to know.
And now that the box is bolted up, make sure it's centered before you attache your steering shaft and pitman arm.
Is it a dropped arm for a lift, or a stock arm?
Unless they say it's centered already, and you have not had to twist the shaft during installation, turn the input shaft all the way in one direction then back all the way in the other, counting the turns exactly. Then go back exactly half-way. The box is now in it's centered position.
Now you can connect the shaft in such a way as the steering wheel is straight.
The pitman arm can go on, usually pointed straight back.
