- Joined
- Nov 3, 2003
- Messages
- 51,622
Definitely!
Thanks for the pics. You definitely need a dropped pitman arm and trackbar bracket, or, depending on what use you intend to put this EB to, a riser plate (stronger than a drop bracket).
If you opt for a riser though, instead of, or in addition to the dropped pitman arm you would want to do a tie-rod over conversion to get your linkage geometry back into sync.
You said a 3" lift was added, but since there is no drop arm or bracket, you have to do something to get those angles back down to an even remotely normal level. You were commenting on steering issues, but aside from the stabilizer mounting (which might not be the main culprit after all) your linkage angles are just way too steep.
And when you add all that to the fact that you have manual steering, all that odd feedback can make it's way back up to the steering wheel with little isolation. Power steering runs quite a bit of interference between the tires and the driver.
Good luck. Got a whole can-o-worms you might be opening up. But it's all fixable at one level or another.
Oh, and what C-bushings did you opt for? With your year, and that amount of lift, you'll need 7° bushings. And even at that, still cross your fingers that you'll have a decent amount of positive caster.
A '66 would not have had much originally because of the manual steering. Lifting the ride height makes it worse. Bigger tires makes it even more important, and power steering becomes almost a necessity.
