EBashleigh
- Aug 1, 2017
- 8
It all started with a simple clutch replacement......which lead to realizing that my 289 is actually a 5 bolt 1964 289. (Engine swap was done by a previous owner, my bronco is a '71 originally with an i6). While replacing the clutch I also started installing power steering, which is all factory components (at least to my knowledge). When trying to install the pump with the 6" pulley, it interferes with the power steering box. In my attached pictures I have a lot of washers behind the pump and bracket to try pushing it out more, which doesn't solve much and still looks like I'd only be able to run a 4" or so pulley.
So.....this leads me to think that the engine may not be in the correct location. When pulling the trans and tcase I also realized that the PO has drilled new holes into the cross member side brackets as well as extending the tcase shifter hole farther forward. This lead me to believe that the motor mounts they welded in are a couple inches too far forward. So, naturally, I measured the location of the motor towers. Going off of Tom's site, which states that the center of the towers are 11" from the front cross member, mine also appear to be 11". Now I am stuck, because as far as I know, the early 289 is the same size as the common 289, I also know that I have a V8 RAN trans ?:? ?:?
Any help would be greatly appreciated, also maybe some measurements to help me determine if my engine is positioned incorrectly. Thanks!!
https://drive.google.com/open?id=1fk5m5r5F_joLtKXzxfIRipkRm5vJpDYL
