Depended on the year (maybe), the tire size option, the transmission and final gear ratio.
I would think anyway. Maybe there was one size, but I doubt it.
Oh, and there were two sizes of drive gear inside the transfer case too, just to muddy up the waters a bit more.
Someone will know for sure. I just thought I'd say howdy and rain on your parade temporarily. ;D
I think the factory 4.56 and some/all 4.11 geared Broncos came with the 6 tooth steel drive gear and the 3.50 geared ones had the 7 tooth plastic drive gear. The difference in ratio between 3.50 and 4.11 is 17% and the difference between 6 and 7 teeth is 17%. That way the same driven gear could be used in both and it would leave some adjustability for different tire size options.
I can't remember what the stock driven gear was in my Bronco but it had 3.50 gears and the 7 tooth speedo drive gear.
BTW, You can look inside the speedo gear hole and count the teeth on the drive gear. Or if you can't count them the steel gear has 6 teeth and the blue plastic one has 7.
Just a thought...would there be a chart in a factory shop manual listing which speedo gears were used with with which axle ratio and tire combos?
My stock gear was the white 17 tooth with 3.50 gears. I stepped up to a red 21 tooth for 4.88's and 34" tires and it seems to be pretty close, although I haven't borrowed your GPS yet to verify...
Good idea, Dave! So I looked. In my '73 edition, it says:
The Ford Truck Master Parts Catalog shows the proper speedometer gears to use for various rear axle and tire size combinations.
Todd Z.
Oh well, sounds like you're slowly getting the answer from the Group Mind anyway.
so for a stock 77 with 3.50 rear to 4.10 and 35" tires what should I get for a speedo gear? Are they easy to swap out?
