Strange engine miss
ep67bro
Bronco Junky
Easton, MD
The bronco has a 289 that I rebuilt about 5 years ago and a NP-435 4 speed trans. Stock motorcraft distributor, new plugs, new wires, new cap, new coil, new points and condensor. The carb is a Holley 470 TA less than a year old.
The bronco ran fine unitl last week I was running it hard on the highway about 70 75 mph and it seemed to break up! Got back to the shop and truck developed a bad miss just above idle! So I replaced all the plugs wires points and condensor and it still did it! I even swaped my old 600 holley on the motor and it still did it. Thought that i may have a bad valve even thought there is no valve noise so I did a compresson check on the cylinder that seemed to have a fouled plug and it check out good.
Came back to it the end of the day took the cap, and wires off my 73 put it on the 67 and the truck ran fine???? So I assume that I had a bad plug wire.
Today got new wires Accel Super stock 8mm put them on truck runs good for a while then starts to develop the miss again after the engine is warm. It seems to miss when you are just crusing. If you get on the gas it smooths out until you let off? I am Lost dont have a clue what to try. I even tried taking the bowl off the carb and cleaned all the jets and needles everthing looked brand new with no dirt. HElp HELP!
I am wondering if it could be the distrubutor itself.
Swap the '73 distributer and find out.
Run hard, then had the problem. Changed all the ouside parts easy enough. Leaning toward a tight (but not yet burned) valve personally.
nrramse
A vacuum guage might be telling here. If a valve isn't right, the needle on the vacuum gauge will quiver (that's what I've read anyway - I've never seen it actually happen).
Newell
ep67bro
ep67bro
Bronco Junky
Easton, MD
Well I will have to get a vacum gauge. I think I am going to swap out the distributor tomorrow. I am putting a lift on a guys bronco today. I really hope it is not the valves!!! I dont have the time or money to have the heads done on this thing!!
ep67bro
ep67bro
Bronco Junky
Easton, MD
Got a chance to swap the distrubutor out of my 73 into my 67. It seems to have fixed the problem. Drove the truck for around an hour at differant speeds and no miss or loss of power at crusing speed. Do seem to have more back fire when I let off the gas but that could just be the timing. Looks like I will be ordering a new distributor anyone have a suggestion of brand? I want to stick with a stock points type. I was looking at the Accel OEM replacements any input?
phred
Earth
Could be a cracked cap. Had one do something similar. May want to swap the old cap back on the new dizzy just to see. Caps are a lot cheaper.
ep67bro
ep67bro
Bronco Junky
Easton, MD
I have checked caps. Actually I have tried three differant ones no change.
