Stretching wheelbase...why?
broncow72
Village Idiot
Spring,TX.
SaddleUp said:
My F250 is 155" so I have an idea of what your talking about. I'm with Mike above. A pair of 609's under there with hydro rear steer would cure that.
And it would be waayy cool. Unfortunately, not street legal. I drive by this guys house every day that has 2.5 ton rockwells under a suburban with 4 wheel steering. He claims to be able to do a U-turn in a residential street.:eek:
SaddleUp
Vancouver, WA
Do you have any statutes (Federal or State) that you can point to that says it is illegal? There are factory cars with 4 wheel steering and they don't appear to be illegal. Nor do I know of any safety issues with it since the rear axle will always self center if the castor is set up right. (As long as you use the right valve)
Hogback
It could vary between states, but since they do make factory 4 wheel steering it should be legal as long as it has a mechanical system and not full hydro.
broncow72
Village Idiot
Spring,TX.
Bingo!!!
SaddleUp
Vancouver, WA
Why would mechanical vs. hydro make a difference? I've never seen anything that says full hydro steering is illegal. On the contrary I know that some construction equipment that is street legal uses full hydro steering. As far as safety hydraulics are more reliable than mechanical components so I don't see where that would be a problem. Personally I think this is just like the beadlocks where many people claim they are illegal yet no one can come up with any statutes to actually support it.
welndmn
Some states say you can not change the steering from factory, or even use rod ends for the steering.
In CA full hydro is legal for street use.
BUCKETOBOLTS
Salisbury, NC
I can remeber in the early '90's Honda had 4 wheel steering on the Prelude. Then GM had rear steer on its long wheelbase trucks just a couple of years ago.
I've had a good bit of experience working on fork trucks and other construction equipment. I've seen many balljoints and rodends fail, but never had a hydro system fail catastrophicaly. Yes an ocassional leak, but never a loss of steering. And I believe that most systems will still turn if the pump stops pumping. I plan on using a hydro on my buggy, tagging it as a '77 Bronco, and driving on the street.
SaddleUp
Vancouver, WA
BUCKETOBOLTS said:
....And I believe that most systems will still turn if the pump stops pumping. I plan on using a hydro on my buggy, tagging it as a '77 Bronco, and driving on the street.
Yes, as long as the correct valve is used it will still turn. The valve actually works as a pump under these conditions and it is reported that it is about like trying to turn a normal power steering vehicle after the pump has failed.
I too plan to go with full hydro so I can move the frontend up further (I want the tires even with the front of the body) and I will still be driving it on the street unless someone can point to something that actually says it is illegal. (I would even want to read the statutes in the states that it is "supposedly" illegal to make any changes to the steering) Any law that states such is going to conflict with other laws or is going to severely limit what is done regularly by many federal and private organizations to build vehicles meant for special purpose uses. Both buy factory equipped vehicles and then have them modified to fit their needs which on some occasions involves steering modifications. 4WD ambulances and 4WD school buses are 2 such instances where I know this is done since we use to build them in the 4WD shop I use to work in.
scsm76
Shaver Lake, CA
It was probably due to pour maintanence or excessive wear but I have driven construction equipment with full hydro that would turn it self to one side or the other with the steering wheel staying in one spot. Most properly working stuff stears great and still functions with engine not running. Steering hoses do fail.
As far as legality I think the only time it would come into play is if you had something large enough that required a dot inspection or if you caused an accident due to the failure of your modification. Unless you could prove your insurance company was aware of the modification they would not cover the accident, this includes lifts and larger tires.
SaddleUp
Vancouver, WA
scsm76 said:
It was probably due to pour maintanence or excessive wear but I have driven construction equipment with full hydro that would turn it self to one side or the other with the steering wheel staying in one spot....................Steering hoses do fail.
This could have been due to the type of valve and ram used. If you don't use a bidirectional setep then this can happen. It also causes the steering to move more for a given number of turns in one direction than it does on the other. The right parts prevent this though.
Yes, hoses do fail sometimes. Usually due to poor maintenance or improper installation. Tie rods and steering u-joints also sometimes fail for the same reasons.
Madgyver
Bronco Madman
In our state anything welded to a frame or anything structual (sp?) needs to be done by a certified welder and then go to a reconstruction permit process.. Or else the vehicle will not get registered which to me is all BS to me but in a way safety because the is alot of charactors (sp? again) out there who thinks they can weld.... and build unsafe custom rides..
OX1
Does that mean any bolt on structural items are OK then?? ;D
welndmn
Yeah, with the correct valve you can turn with out the pump.
When I lost my fuel pump, I was towed back out to my trailer.
Steering is NOT EASY and is something I would rather never do again, its hand over hand turning, with your foot pushed into the tranny hump for more leverage.
