Stuck bearing/hub
ntsqd
heratic car camper
Upper SoKA
Classically the wheel hub's design goal is for the wheel mount flange to be placed where the tire contact patch is centered between the bearings so that both are loaded the same. That is when the bearings are the same size. As the difference between the bearing sizes increases, the flange moves more and more towards the larger bearing. Pretty logical when you think about it, bigger bearing carries more of the load.
Bearing pre-load + the loading keeps the inner races from spinning. Unless you build a spacer similar to the pinion bearing spacers found in the rear differential. For any use where you're going to work those wheel bearings really, really hard this is a good idea, but it's not always trivial to make those spacers and they should be hardened at least a little. For the average enthusiast this is massive overkill.
These are big bearings, don't be afraid to put some pre-load on them. Use a good grease, something like Redline's CV-2, in brand name bearings and you'll likely never take it apart again unless something else requires it.
In my mind emery paper and crocus cloth are both on a woven type of backing. Both can be either a sheet or on a roll. Emery is in the 200 to ~800 grit range and crocus cloth is 1000 grit plus.
For a problem like this you want a roll so that you can grab the ends and wrap it roughly 180° around the spindle. Pull back and forth on the strip while also slowly working your hands around the spindle in a circle so that you remove equal material all the way around.
PaulN
PaulN
Unfortunately although I foresaw it coming and tried to be careful and stay outta the way, I messed up and slipped and took a seal puller to the forearm and had to get stitched up……
Anyone got any tips for taking off the inner bearing grease seal easier? Should I just heat it up. Also I realized the seal puller might have been too small because it didn’t reach the edge of the hub and was prying from the other edge of the seal and so when it deformed the prying edge it slipped. Figured what was the worry that could happen but
SLOWnEASY
San Diego, Ca.
Ouch that sounds painful. Seals are just a pain and I've never found a one size fits all process for pulling. Typically I start with a seal puller that is basically a hook with a spot that you can tap with a hammer. Come to think of it I'm not sure I've ever been very successful with this puller. I should probably just stop trying to use it.
https://www.matcotools.com/catalog/product/sph/seal-puller-with-handle?referer=ZVNlZ21lbnRfMTQ0NjI1
Next I grab my Harbor Freight 24 inch pry bar and try to pry it out.
https://www.harborfreight.com/pry-bar-set-4-piece-58388.html
If that fails I move to using a small flat blade tapped at an angle between the housing and the seal and start folding the seal in. Try to make sure the blade is angled inward so the corners do not scratch the bore of the sealing surface. Once you get a bit of the seal pulled away from the bore substitute in a larger blade and tap pry some more.
That's basically how I get them out.
ntsqd
heratic car camper
Upper SoKA
A friend showed me a trick that has worked every time I've tried it. Remove the wheel bearing nut, washer, and outer bearing. Thread the nut back on just far enough for all of its threads to engage the spindle. Pull on the wheel hub like you're using a slide hammer (because you are). The nut should hang up on the inner bearing, which will push on the seal and knock it out of the hub.
SLOWnEASY
San Diego, Ca.
I many times use the outer nut as a slide hammer to pull the inner bearing. But all to often I find that the nut is too large to slip inside the outer race to reach the inner bearing. And I question if this technique puts undue stress on the bearing rollers. If you think about it when we do this we are transferring the slide force from the inner bearing race through the end edges of the rollers to the outer bearing race. This has to be hard on the bearing cages, the end corners of the rollers and the edges of the outer race. Am I going to stop doing this tomorrow? Probably not. But I do sometimes question if I really should be doing it.
ntsqd
heratic car camper
Upper SoKA
I've not tried this technique on a passenger car, maybe those won't fit. Have yet to not have it work on a 4x4.
If I'm pulling the seal the bearings are being replaced and I don't care what duress I'm putting them under.
Sorry to hear about your mishap!
I’ve had very good luck with those types of seal pullers over the years. They don’t work for everything, but when they work, they work really well.
The one we sell has a regular round handle, however, and seems to be easier on the hands than the flat bar stock.
So far I’ve avoided forearm tragedy, but it’s still got the same two sharp edges to watch out for.
I like the factory method described in the book post previously. As long as I don’t have to beat on the bearing to get there. Which you probably do.
If you’re replacing a bearing, that’s not a problem. Then again, a bearing that can handle the weight of a vehicle on it, can probably handle a few decent whacks with a hammer without distorting.
But as was said, I wouldn’t try too hard. The cage is the weak link and you don’t want to distort the cage, taking out the bearing just to get the seal off.
Ultimately, if you don’t mind the extra work, using that method to simply remove the bearing race and taking the bearing and seal with it, would seem to be a good method.
But I’ve never tried it…
PaulN
PaulN
Thanks all for the advice I really appreciate it! I’ll update with how the bearing is once I get it all back on and preloaded and set.
PaulN
PaulN
Is a Knick like this on the rotor sandable?
ntsqd
heratic car camper
Upper SoKA
Do you have a body work type long board that is stiff? I use one of those with self-adhesive 80 grit to 'condition' a rotor for new pads. it should make short work of that.
PaulN
PaulN
So got everything back together and went for a test drive. Things felt good until all of a sudden I started getting excess bump steer and wobble when I hit the front driver tire. I jacked up the truck and grabbed the tire 12 & 6 and there was a bit of a wobble….
Some backstory, I replaced my driver side hub, bearings and spindle because i had a loose hub like almost 1/4” of play. I replaced the hub, spindle, both bearings/races, the only thing I didn’t replace was the spindle nuts but they looked fine and still had the prong sticking out.
I haven’t opened up the passenger side yet to repack the bearings but it doesn’t have wobble. Also I’m not sure how much drag the tire should have but the passenger side I can spin it somewhat easily but for instance couldn’t grab it and spin it and let go whereas the drivers side I can give it a spin and it’ll turn 1/4 rotation without actively spinning it. I was thinking that was too loose?
Does anyone have any ideas? Should I have replaced the spindle nuts and maybe they’re not staying locked even though they look fine?
I loaded the bearings to 50 ft lbs while spinning the hub. Backed off 1/4 turn. And then hand tightened so I could get the prong to lock. Tightened the outer nut to 100 ft lbs.
Could maybe my wheel backing plate be warped and it’s not the actual hub but just the wheel (seems like the entire hub has play though)?
My axle is also shifted 2” to the passenger side and just got an adjustable track bar I will install.
Slowleak
Georgia
Sounds like you may have some bad track bar bushings. I would get under it and look while someone turns the steering wheel back and forth. See if you see any movement where it shouldn’t be. Make sure the steering box is tight on the frame. You might also want to recheck the torque on the driver side spindle nuts.
nutter3
If you have up and down movement on the DS, you probably need new ball joints. Definately recehck the spindle torque.
As for removing the inner grease seal on the hubs, I've always just hammered it out using the bearing. They are not in there that tight, and I have never damaged a bearing doing this.
SLOWnEASY
San Diego, Ca.
Unfortunately a bit of wobble is entirely subjective. You could retorque the drivers front bearing if you want but it's not the cause of your bump steer. But the spec on end play is something like .001 - .003in so there should be a tiny bit of play when you grab the wheel at 12 and 6 and wiggle.
Also I would imagine your spindle nut is fine. As long as the pin is on the inner nut and facing out so it engages on the holes in the washer it will be fine. Remember a little bit loose is way better than a little bit too tight. That's why the process is to back off the inner nut until the pin goes into a washer hole. Also I think if the pin isn't lined up on a hole try flipping the washer over first before backing off the inner nut.
For the bump steer as said above I would get somebody to wiggle the steering while you watch the linkages for excessive play. Look especially at the track bar bushings.
What caused the axle to shift 2" to the passenger side? It seems to me that a suspension lift will cause the axle to shift to the drivers side as the frame goes up. Did you lower the Bronco? Regardless, replacing the track bar with an adjustable will serve the dual duty of replacing the track bar bushings at the same time as repositioning the axle so that is a positive.
ntsqd
heratic car camper
Upper SoKA
These are big bearings, a little tight is not going to hurt them. A little too loose will put the OP back exactly where he was when this all started. Loose bearings will spin on the spindle.
Frankly, I think that the factory spec of slightly loose is a very bad idea that keeps getting repeated. These bearings want some pre-load on them. Pre-load is how you keep the inner bearing from spinning on the spindle. With smaller passenger car front wheel bearings it is much more important to get the pre-load right and just a little too tight can have bad consequences. Not true with these bigger bearings, they'll tolerate a little too tight by only running a bit warmer than they should.
I've learned to lay my hand on the exposed part of the wheel hub after driving any distance to check the temperature of the bearings. The hubs should be slightly warm to the touch. Too cold or too hot both mean that there is a problem.
Use a good grease and give them a little pre-load. I use Redline's CV2, which is a synthetic grease intended to be used in a much more severe location, a CV joint. I don't think that there is a more demanding place for grease on any car or truck than in a CV Joint. This grease used in a brand name bearing (Timken, Koyo, SKF) set with correct pre-load will likely last a life time.
I spin the hub by hand and tighten the first bearing nut with a ratchet in the socket, spin and tighten, spin and tighten until I can not spin the hub. Then I loosen the nut until just finger tight. Using the socket only, no ratchet I then tighten the inner bearing nut as tight as I can reasonably get it. Install the washer and index it on the little pin. If it won't go with the washer tried both ways then tighten, only, the inner nut until it will. Torque the outer nut to it's spec. This process duplicates the live front axle wheel bearing tightening process documented in the Toyota Factory Service Manuals but without using a spring force gauge to measure the torque needed at a lug stud to spin the wheel hub. I've been greasing and setting these bearings this way since 1998 and have never had a wheel bearing problem.
