On my 76 E-150, my brother got a couple small sharp knives and slipped each one up under the gas cap and wiggle them both against the spring loaded latches until they both were pushed back into the cap far enough for the cap to slide off the filler tube.
You might also try to pick the lock. They are pretty simple, and cheap to replace if (when) you bugger it up.
I got my 77 with a locking cap but never got the key. I worked on it with two screwdrivers, a prybar and it came off in about 45 minutes. I would veto the idea of drilling it.
Even if you were careful and it didn't go "boom," you'd still more thn likely end up with a few metal shavings in the bottom of your gas tank, which may be okay until it finds the outlet line to the fuel pump.
I had to do this last week. I just pryed it off with some screwdrivers. If it was like mine, if you take the metallic sticker with the writing on it off. You will find 4 tabs that hold the out side of the cap to the main piece. If you pry on it enough they will brake through the cap piece from there just use the screw drivers to push in the tabs that hold the main part of the cap to the filler hose. Just be carefull not to push that piece into the tank.
