Stuck Gear Selecter
NC-Fordguy
Bethel/Greenville NC
Hey Guys
The Specs...1974 C-4 with selector on the column
Fired up the beast for a little trip today...backed out of the driveway and put the truck into Drive went about 50 feet and then it acted like it was in neutral...no forward engagement. Backed up into the driveway and now I can only physically shift into park and reverse. The selector feels like something is binding it....where should I start to look to fix this?
Ed
TJK74
Newark CA
I'd start by looking at the shift linkage off of the tranny. there is one bolt that holds the shift rod to the tranny shift linkage. it this works loos then the shifter slides in the slotted bolt hole making it unable to reach all the gears
NC-Fordguy
NC-Fordguy
Took a look underneath...Looks like the shift rod is attatched correctley. Should I remove the rod and try to turn the lever on the transmission???
Not sure what I am doing here.
Ed
TJK74
Newark CA
I would give it a try. Undo the shifter at the tranny and with your hand. rotate it all the way up into PARK then postion your shifter on the column in park as well and bolt it back together and see if that helps. While your down there before you hook it back up see if you can rotate the linkage on the tranny through all the gear by hand. If not then its a problem internally in the transmission
