Stuck in gear
KeithBPatrick
Lubbock
Hey all,
I could use some help/advice, I'm no pro-mechanic so take it easy on me. I recently had a new Tom's column installed when my mechanic pulled my blinker switch and found that my column was stripped down to nothing inside, the steering wheel was holding everything together. After a failed coupler was replaced on that column everything seemed to be running great. There was a little front/back slop in the wheel, I could pull back and get about 1/8" of movement between the turn signal housing and the wheel collar. I suspected that would cause some wear but my mechanic said there was no way on installation to tighten down that slack.
My first question is if anyone has experienced that slack in the column or if he's full of crap.
Second, and more importantly, I got stuck in gear turning onto my street this afternoon. I assumed it was column/linkage related due to what I said above. But I quickly realized it wasn't about spacing or lubrication, I couldn't get the shifter to move around at all. I got underneath and found I could easily manually articulate one of the arms on the tranny, but not the other. I disconnected the linkage that wasn't moving and found the stuck linkage moved fine, it was the tranny arm itself that wasn't moving.
Any thoughts or experience with this? It's not an easy problem to search for on the Google machine or in here. I was able to roll it back into my garage but if there are some options for me to get to work on it that'd be great. Or do I need to prepare to get a new transmission?
Thanks in advance for the help.
LilMixedUp
Bonaire
so its sounds like you have a standard 3 speed on column? Being how you disconnected shifter from trans and shifter moves but the transmission will not shift manually, it could any number of things inside the transmission. Bad thing is you will have to drop it to open the top cover and inspect. Afterwards you can then make a decision as to what needs to happen. worse case, broken shift rail...easy fix will be a broken tooth off one of gears stuck between the cluster. If you like your 3 speed there are plenty of rebuild kits available for less than $150... it isn't hard, just get you a manual and take your time. Good Luck
K
KeithBPatrick
Lubbock
Yeah I do have a 3 on the tree, sorry should have specified. An update after I rolled it into the garage I got back under and the previously locked arm now moves and the other is locked down.
Since buying the rig I've had the plan in my head to do an NV3550. I prefer floor shift and the control of a 5 speed so maybe this will be my opportunity.
SHX669
Been years since i messed with a stuck 3 spd but disconnect the linkage( round arms" ) from the "levers" at the transmission. Seems I remember if you turn the lever that moves vertically a lot of times youre then able to turn the other lever vertical also . I think thats nuetral and should free things up - maybe ! Sloppy unadjusted shift linkage can cause the gears to bind (trying to go into one gear before the other - uh - " goes out "
Yep. Before tearing into anything or figuring on starting your 5-speed install (although that's a great excuse and result!) just make sure it wasn't a temporarily jammed up interlock.
Only one lever is allowed to move at a time, so if one is not perfectly centered it can jam up the other one. This is usually a result of a slight misadjustment of the long rods from the column.
There's a procedure in the book for setting them that's pretty easy. You should definitely have a book if you're going to be working on one of these old rigs.
Basically though, the stock columns have a small half-tube welded to the top of the outer body down at the levers in the engine compartment. You insert a drill bit into it (1/8" I think?) and through the small holes in the two shift levers to line them up perfectly centered where they should be when the trans is in neutral.
Then, with the levers locked into position, you adjust the rods as needed to fit into the levers on the side of the trans with no pressure.
Better to have the book rather than to listen to my long-winded descriptions, but you get the picture hopefully.
Look for that loop for starters, and go from there. You've already done the dirty work of disconnecting the levers.
Good luck
K
KeithBPatrick
Lubbock
Awesome advice! Finally got the 2nd linkage off and was able to get things back into neutral. I had my column replaced a while back with a TBP column, so at first I didn't see holes. They were incredibly tough to get to as they are in pretty tight next to the rag joint and all tucked under the master power brakes and master cylinder. My rig has 2" of suspension and 1" of body lift and sits on 35s, so I have to stand on the bumper and get real uncomfortable to work back at the firewall like that. Anyway, got it all recalibrated, it's working as it should now. I definitely need to order a new set of bushings for the lower connections.
Thanks again everyone, learning every day.
K
KeithBPatrick
Lubbock
DirtDonk, do you have any suggestions for where I can find bushings for the tranny end of those linkage rods? I keep seeing the Lokar kit but I'm not sure that's what I need. I don't really need to replace all of the rods, just the bushings and pins.
K
KeithBPatrick
Lubbock
Paul,
Those WH bushings look similar to what I'm seeing online. I found a set that's for the tranny arms on TBP, but they say you have to drill out the shifter arms to .74" for fitment. So I guess drill it to 19mm?
gr8scott that is awesome! I ordered one last night.
Hey Frankt, welcome to classicbroncos! Sorry to hear you're having an issue, and having to wait for an answer because we're all in food comas probably!
With luck yours is still a simple out-of-adjustment situation. I would at least start with that in mind and disconnect both rods from the levers on the side of the transmission.
Run the shifter through it's paces to make sure it's not binding and works smoothly through all positions. Then set it in neutral. It'll likely flop to one side and they're mostly spring loaded to do that.
Next make sure that the transmission is in neutral by manipulating the levers around until you're sure that they're both clicked into their center, neutral positions. If one or the other is off center slightly, the other one should not actually work at all due to the detent interlocks inside. But it's still possible to get an old tired trans part way out of neutral in one and have the other flop around a bit.
Once in neutral, re-align the rods until they slip into the holes easily.
This should do it if it's actually an adjustment. If it's something mechanical, it'll be time to start pulling things apart.
The bummer about all this is that usually the shift rods and levers are a little more awkward to work with than you'd think. They're easy to see, but unless you have really small hands and a good back and neck, it's hard to get up into the tunnel area from underneath.
If you can get to the tunnel shifter cover and remove it, you "might" be able to do some work from above. But I'm thinking it's easier from underneath.
Good luck!
Oh, and if you have not had the Bronco long, do you know if the gear lube has ever been changed? Unless you had a really good PO (previous owner) it's still possible that your 40 to 50 year old transmission has never had it's oil changed. Plenty of them still out there.
Even very diligent owners that change the oil every 2500 miles (even though you don't need to do it that often) they may never have done the differentials, transfer case or transmission.
So this may turn out to be the time to do those things as well.
What year is your Bronco?
Wyflyer
Paul, thank you for the time you spend helping people out with your tech advice. Or should I say "Obi-Donk-Kenobi"?
No problem! Thanks.
Glad I can help, when I can help.
Now we'll just have to wait and see if this was one of those cases or I was blowing smoke and other hot-air items and we need to move on to a Plan-B next.
Whatever that may be.
