Stuck in Third!!!!
abby
just put the rig back together. blew my 3 speed. had to get a used from a friend. all in place, everything went well.
But
I can't get it out of third! what gives. is there some rule that applys to re installing that i did not do?
any thoughts on jamming it loose?
the thought of pulling it again is well, not making me happy:-X :-X :-X
chuck
Nobody
Stanwood
Let me guess...column shift? You have to shift them square, and carefully. Faster shifting comes with experience. There is probably a combination of worn parts in the linkage/column.
The good news is it should be an easy fix. Pop the hook and manually shift the linkage at the column. Make sure you block your tires or set the ebrake so it don't roll away.
After awhile you'll be a pro at shifting.
A
abby
it gets worse.
ok so i un stuck it. put it in 4 low pop the clutch. bam out of gear. however.
it won't go in any other gear. also, smoking the clutch trying to find 1 2 or R. only will go into 3rd.
i blew up my hef 3 column, which shifted like dream. so i put a used 3 speed rat in from a bud. used his adapter to the dana 20. took off my linkages from the hef, put them on the rat so all is lined up.
i'm bummed. i'm getting the feeling this tranny is toast.
but i'm holding out for a quick fix. maybe a hammer to the tranny, knock something loose??? :D :D :D :D
Viperwolf1
electron whisperer
Disconnect the linkage and try shifting the levers on the trans itself. One side needs to be in the mid position (neutral) to get the other to move. If the trans shifts ok like this the problem is in the column or linkage or adjustment.
