Surprised/depressed after flare installation.....
airbur
Castle Pines, CO
So I had Bushwackers installed this week in prep for new rims/tires and was surprised to find how they were installed on the rear. I am very used to seeing them where they are equal distance between the fuel caps. These were installed further forward. I can understand the shop's reasoning....gives more room for larger tires...but with 33's or 35s, I can't see the need. I'm very unhappy with how it "looks", but functionally I know this is probably better.
Any words of wisdom? It's going to take me a LONG time to get used to them.
lonesouth
wait to pass judgment till after the new rims and tires.
airbur
airbur
Castle Pines, CO
Yea....I guess there are so many that have been done wrong, I got used to, and liked the incorrect installations.
Socal Tom
San Diego, CA
Yeah, its a bummer when what you expect and what you get are two different things. There are a lot of things on these rigs that can be done more than one way. Its part of why I ended up doing things on my rig myself.
Tom
airbur
airbur
Castle Pines, CO
Yea....I've done most everything else. I wanted a pro to do these though since it's a visual thing really. Ah well, I see how the tire will be centered much better this way.
siderbox
I can see how you'd like the equidistant between the caps.
I'm torn between the two.
I like the fact that they are installed correctly, center with the axle.
The tire to flare will look better spaced equally.
But the flare looks better spaced with the caps.
I'm liking more and more having on tank so I don't have to worry about the placement of the flares.;D
Billings
My fiberglass ones were centered and at the time 31 inch tires broke the front edge. I trimed a bit off the leading edge to fix it. You will be happier with them slightly forward. Mine
mitzel
Googleplex
If that flare is moved back to center between the filler caps then even a
33" tire often starts to rub on the front edge. I think your flare is setup
perfect if you're planning on a 33"-35" tire!
If the look really bothers you in the future a fairly easy change may be
to swap to a flare with a larger opening. Then you can still have the front
of the flare in the same location, trim a bit more at the rear, and it may
fill the full space between the filler caps. Something along the lines of
the Wild Horses Wareflares might be an option.
Greg_B
Cohutta, GA
Mine are centered and my 35s busted off the front of the flare on my first MILD offroad trip. I had to trim the front edge off both rears...
I think this will work out well for you... If you had one cap it would be great...
Greg
Nightmare Bronc
I think they turned out really nice. It will really look good when you get your new tires and rims on.
JakeAlex
New Albany, MS
Remove one of your gas tanks and fill in the filler neck hole on the body. Problem solved. :cool:
As I was reading through the responses, I was going to say what Justin said. You "could" do as I did and remove your AUX tank, upgrade the main tank to a 23 gal and just do away with your AUX tank hole. This is what I did on mine. Just a suggestion.
Looking good btw...
Viperwolf1
electron whisperer
Mine are centered on the caps and the 33's have met the front lower edge of the flairs many times.
Hoppy
Gresham, OR
How about a longer filler tube and move the AUX tank filler and cap closer to the driver sticker post
mavereq
i think i'd rather have the flares centered and the axle moved back... just sayin
RubberTramp
I think it looks good it will look awesome with some new wheels. weld up the aux tank hole and she will look great i always wished my old ones were centered. but i put new war flares on it and centered them and done away with the filler necks and put a fuel door on for the main and it worked great.
