Hi, the Pertronix Igniter is a great choice. Pair it with the Flamethrower coil. You will have to feed the new coil and igniter with a twelve volt wire, key on only of course, or remove the pink (I think) resistor wire under the dash.
Pertronix now has three different levels of the Igniter . I would choose #2 for my Bronco, #3 seems like overkill.
By the way, I see you bypassed the vacuum retard on the vacuum advance can. Many guys feel the inner nipple should be left open so the diaphragm can be free to move in response to engine vacuum.
Good luck
