BoulderBronco22
- Joined
- Oct 1, 2012
- Messages
- 234
So I have a flat tappet cam on my 351 that I've converted to EFI using the cam synchro shaft and sensor from an early 2000's 3.2L F150. I have changed the gear from the steel gear to an iron gear so that it will be compatible with my iron cam. I have used a new synchro shaft from the parts store each time and each time, I can press the gear onto the shaft by hand. The OEM part requires a shop press or a big hammer to get the gear off meaning it shouldn't be that easy to take the gears off and back on on the re-man Chinese junk.
For the 3rd time, the roll pin that holds it in place has broken and I lose all oil pressure. I'm not using a high volume oil pump. I feel my best solution would be to get an OEM from a junkyard and swap the iron gear on that so there is less stress and pressure on the roll pin.
Has anyone else had this issue and found a solution? Any other ideas or suggestions on how to solve this?
