Does anyone know if the same t bird caliper upgrade we use on our Broncos will work on all late 70 s Dana 44s? Like a full size?
I put them on my 79 with a camper. I am running an f350 master and booster with f250 rear wheel cylinders. It stop way better than my super duty.
What year is the master and booster off from? And th rear wheel cylinders? What kind of rear are you running?
I don't do any towing but this truck has 44s on it. It used to not be an issue but as of late the brakes have felt a bit weak.
Thanks!
For you guys doing the swap I'm pretty sure you need to change the outer (soft lines) to the caliper too. I think the fitting size is different on the t-bird caliper.
are the brake pads the same?
the big bore caliper takes a 7/16-24 banjo bolt which is a bit of an odd ball.
you won't find them at the standard auto parts store. they will only have a 7/16-20 and look at you like you have 2 heads if you ask for it.
i know Speedway motors & Summit sell them.
curious what others have used for lines..anyone want to chime in.
i have used off the shelf hoses for a 80's blazer as well as having custom lines made.
