NicksTrix
- Aug 1, 2001
- 6,389
TZ you know i love me some AN pieces as well. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
i was looking for an option a few years back and found i can make the blazer lines work with just a little bit of work. the inlet hole on the caliper has some ribs that need to be ground flat so the banjo block can sit flush. the corners of the banjo block might like a little relieving to help gain a bit of angle. the line comes with a bracket that is just crimped on about halfway up the hose. i remove those. they must have bolted on the gm spindle. i'll send you a pic
