T case swap
Redmoon
going to run a c4 auto , to go from a J to a T transfer case would I just have to change the main drive gear ?
Fastwest
If you’re just swapping the trans, either tcase will mount to it as long as you have the C4 adapter between the two.
R
Redmoon
went from a 6 cylinder 3 speed to a 302 auto , ended up with an extra T case at some point and for some reason I sold the other one with the 3 speed
AZ73
T D20 is 2:46. J D20 is 2:34. My understanding is the gears in a T are slightly stronger. Twin stick is a problem unless you remove the pills connecting rails on a T. My rebuilder forgot unfortunately, and I didn't relize it until I already installed it. :( No problem with J
jckkys
After years of driving both T and J styles I would choose the T shift, if for the simplicity of operation. The better low range gears are a bonus.
tabyers
Indiana
This might be slightly off topic (been good at that lately, sorry) but it was my belief that as long as you didn’t want front wheel drive only, leaving the pills in your t-shift was optional. Is this inaccurate?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
You can physically install a twin stick for a t-shift transfer case without doing anything inside, but you have to remove the pills if you want the front and rear to shift independently. The J-shift doesn't require opening up the case to get it to shift independently.
tabyers
Indiana
I guess something must be wrong with my shift rails. I have pills in and 4hi,4lo,2(rear)hi, 2(rear)lo, just no fwd only, as they are still linked.
AZ73
So what does your twin stick Front lever do? to get 4 h/4 l do you have to move both levers to H/L?
tabyers
Indiana
Yes, it just won’t go into front hi and rear lo and vise versa, which I like. My understanding at the time was that leaving them in, as long as you didn’t want fwd only, would make them less likely to pop out of gear and negate the need to modify the rails.
