Transmission & transfer case swap question
Sutcavage
Raleigh
I am looking to swap out my original 3-speed with a 5-speed. Would it be wise to swap in a different transmission and transfer case all together? That way I don't have to drop several hundred dollars on adapter plates and all that stuff. Looking for something to bolt up to the 302 that's in it now.
bronconut73
Depends on what you want to do with the bronco. You could swap in a m5r2 with an Np205 and not have to use an adapter. You will still need new drive shafts. It is similar to a 3550, and has no low first gear, but it is all Ford.
M5R2 will get more popular as the ZF's begin to dry up.
They are a better shifting, sportier feeling shifter. There are waaay more of them out there.
They are in fact built by somebody for Ford just like the ZF is.
Mazda built the M5R2 for Ford IIRC. And while it is not as strong as the ZF it is probably a little stronger than the 3550 or AX-15.
As was said above it has a, not very low first gear, this is made worse when running the 205 (just 1.96 to 1). But with the M5R2's OD you can run a pretty low axle gear.
