70 Steed
- Sep 13, 2011
- 268
I've searched the forum and haven't found the answer. I have a '70 with stock 302, stock wiring harness, stock cluster and stock switches. The tach signal wire is a no brainer and I figure I can find a place to attach the ground wire under the dash.
My question is where is the best place to attach the positive and the tach light wires. By best I mean the easiest and most reliable. I know the light wire should be attached to the wire that dims the cluster lights but that is not important to me because I always run the cluster lights at the highest setting. So just a switched 12 volt would be fine. I'm not as flexible as I use to be so getting under the dash to attach to the terminals on the switch is tough. However I'm liking the idea of splicing into the middle of a wire in the harness.
I just thought some of you might have a trick way of doing it.
