Taurus Fan Pics Please
bronccar
Been scouring the archives but too many broken links to external pics.
Planning on cutting core and moving forward. 302 / stock dress / PS / Auto
Thanks!
Timmy390
Conway, AR
bronccar
bronccar
Thanks, found tons of threads but about half the pics were broken links. I have the wiring and controller all figured out - need to see the core support mods.
I know a few people have managed to get it in without moving it but I think my 2" BL has put me dead center of the water pump pulley.
Timmy390
Conway, AR
What front dress are you running and what engine? I didn't think the T-fan required any core support mods?
So no mechanical fan?
Nope none. My 351W came out of a 96 van and I used the 96 van front dress which is LONG. No way to get a mechanical fan in there. I flipped the upper radiator mounts to the outside of the core to gain enough room for the electric fan. If you notice the stock radiator sits at an angle leaning towards the engine. It's still tight but it fits and cools.
Tim
bronccar
bronccar
Thanks!
It generally does. The fan is about 4.5" thick as it is well set back into the shroud.
Is the WH fan 2 speed?
Timmy390
Conway, AR
Yes it is a 2 speed fan. My ECM has built in fan control so it makes it nice.....You only need 3 inches with the WH fan and that's all I had.....I think the T-fan may flow more.....but the WH fan keeps my rig cool and that's what matters.....
http://www.wildhorses4x4.com/product/High_Output_Radiator_Fan_17in/Bronco_Cooling_Fans#pdf
Specifications
CFM high/low: 2400/1800
Amp draw high/low: 23.5/17.4
Width: 16-7/8"
Height: 16-7/8"
Depth: 2-5/8"
Mounting: 8-7/8" x 15-5/8"
Features
Mounts as a Pusher or Puller without flipping blade or switching motor leads
State-of-the-art symmetrical design
High Output 265 watt 2 speed motor (two separate turn-on sources required for 2 speed operation)
2400 CFM on high speed / 1800 CFM on low speed
Ultra-quiet patented skewed blade design
Patented ratchet mounting system
Tim
Skiddy
Thanks!
I have the mustang front dress and had to my core support out around 2", there are others as well. I will see if I can find some pics. basically I just used a piece off of 2x2 angle and moved it out. I hate them external links/pics when searching older threads:(
bronccar
bronccar
Thanks man. I think I saw yours, but I'll take what you can find.
And yes - it's maddening lol
