Do you have a working fuel and/or oil pressure gauge? If they work you have a working IVR (insterment voltage regulator). If all 3 are dead, start at the IVR.
If all that isn't working is the temp gauge, and grounding the wire at the sensor doesn't make it read, now is the time to head under the dash. Actually it is easier to work on the back of the gauges from under the hood, take the driver's side air box out and you have easy access. Find the temp gauge and it will have 2 wires attached to it. One goes to the IVR that is shared with fuel and oil gauges. The other is the other end of the sensor wire. Ground that one. Gauge still doesn't move, now you need a meter. Put on ohms and with both wires disconnected from the gauge measure across the 2 posts. You should get a number, tricky part is watch for an "M" or a "K" on the meter, that is the scaler. A reading with an M, you are probably measuring the resistance between your fingers. Have no reading, the heater element in the gauge is burned out.
That sensor wire has one plug if it appears to be a wire issue. Where the engine harness plugs into the body harness at the back of the intake.
