Temperature Sensor Question
LSUpete
I'm wrapping up a Holley Sniper install and I need to find a spot for their temp sensor. The location I've selected (on top of my Edlebrock intake) has a larger thread diameter than the sensor threads, so I need a bushing to make the transition.
Have any of you run into this scenario? Where did you buy the bushing? I know I can go to the hardware store and sort through what they have, but thought I would check here first to see if anyone has the exact product to use.
:cool:
chuckji
SE Michigan
Usually there are two ports toward the front of the manifold. Driver side is 3/8 NPT, passenger side is 1/2 NPT. Passenger side is typically used for heater core. If you’re not connecting the heater, you can get a 1/2 NPT to 3/8 NPT adapter from the hardware store.
Check the manifold owners manual to confirm the port sizes an threading.
LSUpete
LSUpete
Yep, I will probably use the 1/2" port because I'm in Florida and I have already removed my heater. Also, I have an HEI style distributor and it's size makes that 3/8" port on the drivers side a tight fit.
There is also the one in the top of the available thermostat housing covers.
This fits the old setups: https://www.wildhorses4x4.com/product/Thermostat_Housing/Bronco_Water_Pumps but I bet the 90° type for the serpentine setups has a port too.
Might not be as accurate as the top of the intake (since this is just outside of the thermostat) but not sure what the actual temperature difference is while the thermostat is closed.
The big cap is why I don't use an HEI, but I hadn't thought of the temp sensor location. I like the HEI as an ignition, and my stock air cleaner would not be impacted, but that cap is still just too big for me.
One of the smaller cap versions would be my choice if you don't find the right bushing for your sender. I know which result will be cheaper though!;D
Go to your local Ace hardware. They have reducer bushings in brass that work just fine. Any home center should have it as well, I just find Ace tends to have a better selection. Take the plug you took out of the manifold and the sensor. They will know how to fill the gap.
gr8scott
So I have my stock temp sensor in the driver side intake, and an aftermarket sensor in the thermostat housing. Strangely enough,
and I know it doesn't make sense, but the stock gauge and the aftermarket gauge match each other right up until the thermostat opens.
Once the engine is all warmed up, the stock gauge reads 10° colder than the aftermarket gauge.
gr8scott
That port isn’t vacuum?
On the back of the carb it is. But I think he's talking about the rear port of the intake manifold for his temp sensor.
EDIT: I think I see what you're saying. There's 2 ports toward the rear. One can be used for vacuum and the other for temp sensor or a not-too-hot heater.
...Strangely enough, and I know it doesn't make sense, but the stock gauge and the aftermarket gauge match each other right up until the thermostat opens.
Actually it makes lots of sense to me. I always thought the readings would be close enough, since the metal bits transfer heat through them, and the coolant is still circulating at least slightly around the engine via the bypass.
I guess once the t-stat opens and coolant flows quickly, there is a temperature drop on the other one for some reason related to flow. Perhaps it's just not the hottest point in the coolant system, and all the coolant, hot or cool, goes through the thermostat at some point.
Doing kind of a balancing dance.
But for decades I'd heard many a tale of there being two different temps on each side of the thermostat. Maybe that's true of some engines and not others?
There's gauge variation too of course. Perhaps the EFI gauge just reads 10 degrees high? Hard to say just what's up.
pcf_mark
The only downside to the t-stat housing is the delay in getting temperature. You do not want the EFI to get an incorrect temp until the t-stat opens up. Your dash gage can be delayed.
You will probably be watching the Sniper temp readout more than the original gauge anyway. Betting the sniper is more accurate as well.
Eoth
My two thermostats read a bit different until the engine is fully warmed up. Makes sense since they are in different spots and everything needs to equalize. My first year with my Fitech I did not notice that there was a significant difference between the two thermostats (about 20-25 degrees). Upon further research I discovered that it was fairly common problem with these Fuel Injection Kits. Went down to the auto parts store and bought a new one (generic Autozone) and both are reading the same. In my case it made a big difference in the way the engine ran.
