Third times a charm v3.0
JSmall
JSmall
Did you test fit with the atlas also? You might run into body clearance issues depending how high up in the tunnel you push the trans, which will effect how you build your cross member. Also you will need to make sure that you have driveshaft clearance with the cross member. I am sure you thought of these things but just confirming before you have to redo stuff!
I’m working through all that right now. I need to clearance the body and then I’ll be able to determine how much I need to either notch the frame or the motor mount to get the Atlas higher. I want it as high as it will go without messing with the font driveline angle. After I get it where I want it I will build the crossmember.
JSmall
JSmall
The Atlas wants to fight me ;D
I'm having a difficult time mating it all the way onto the transmission for some reason. The shaft on the trans has been trimmed so that is not the issue. I have a friend coming over tonight to help me muscle it on there.
The small flange on the adapter ring won't seat into the trans
I want to slot the drivers motor mount so I can pull the trans to the passenger side a little (thanks Yeller) which will allow more clearance between the Atlas and drivers side frame, but as you can see, the upper link mount won't allow that.
Good times :cool:
JSmall
JSmall
The art of this is having everything close to everything without ever touching. Your doing well but I see 3/16” available there:p;D
Exactly ;D I’m going to move the trans over a little and lift the everything up about 3/4” from where it’s at now. I’ll build a skid and call it good until I start having issues with it hanging like that.
I’m still not able to get the Atlas to slip into the trans. I had some help today and we weren’t able to wiggle it in there. I’ll take some more measurements tomorrow to see what is hanging it up.
This flange won’t fit into the adapter housing.
snipes243
Huntersville, NC
Wonder if they sent you the wrong clocking ring for the atlas?
I have had good lucky with offsetting the transmission mounting holes on the cross member to move the atlas over, in order to tuck it up higher in the frame rails
JSmall
JSmall
I'm going to remove the rear extension housing off the transmission to verify the fit while on the ground. That will tell me what I need to know.
I can move the trans over about 1/4" before I get into the upper link mount. I will give that a try
JSmall
JSmall
I finally got it. 100% my error with the measurements. Once I trimming the output shaft for the correct clearance it went together without issue.
PNW
Snipes243... you mentioned moving the rear of the trans over... did you also move the engine over to keep ... let's say the DS parallel to the frame rails or is the output shaft angled slightly towards the right rear tire?
Just wondering as I'm thinking I'm going to have to move both the front engine mount and the soon to be constructed rear motor mount over towards the pass side frame rail to gain DS clearance from my Atlas to my frt D60 to clear my 6r80.
Just wondering if the extra angle would stress CV/ujoints at all...doesn't seem like you'd have much of a angle increase for an extra 1/2" of clearance btw the frame and Atlas case...
thanks- not off topic since Jaromy was also looking at possibly having to go this route...:cry:
snipes243
Huntersville, NC
The output shaft is pointed slightly towards the passenger frame rail. I'm currently running a flange 1350 cv head so there is plenty of flex in the joint. Now the front shaft was pain due to clocking the atlas so high up.
BanditBronco
That looks pretty good, about where every one I have seen ends up if you don't notch the frame. It takes a lot to get hung up all the way up there. A nice skid more for your sanity than the atlas and you will be good to go.
JSmall
JSmall
Thanks! I can raise it about 1/2" more if I cut into the floor a little more so I will probably do that. I am working on the crossmember right now and I'm hoping to add a skid plate to that when I'm done.
I would cut into the frame and get it perfect if the body was off and I had more time.
JSmall
JSmall
Nothing is off-topic in this thread :cool:
JSmall
JSmall
Almost finished up with the crossmember. I’ll have the transmission mount bushing tomorrow so I’ll get it finished up this weekend.
PNW
Looking good Jaromy... that crossmember that close to your Atlas will help a bunch for deflecting your case away from rocks, etc... I'm sure you'll do this but make sure when you build your skid plate to have a little bumpout to protect that sight tube... people tend to forget that sometimes we back up and that is the "nose" when backing up...
Yeller
Rogers County Oklahoma
Yep been on more than 1 ride when those got ripped off.......
JSmall
JSmall
Thanks for the tip, Brian. I’ll make sure to do that.
JSmall
JSmall
Super simple, but it should work well.
