JSmall
- Joined
- Feb 18, 2004
- Messages
- 3,224
Did you test fit with the atlas also? You might run into body clearance issues depending how high up in the tunnel you push the trans, which will effect how you build your cross member. Also you will need to make sure that you have driveshaft clearance with the cross member. I am sure you thought of these things but just confirming before you have to redo stuff!
I’m working through all that right now. I need to clearance the body and then I’ll be able to determine how much I need to either notch the frame or the motor mount to get the Atlas higher. I want it as high as it will go without messing with the font driveline angle. After I get it where I want it I will build the crossmember.
