Thoughts on going Coyote?
rye1678
I'm close to the same point in my restore as you are and I am struggling with the very same question. I live in Texas and was at BC Broncos last week picking up my Dana 44 and Ford 9 inch rear that they just rebuilt for me and I got to spend over an hour with Jason looking at the broncos they are restoring and talking about engine selection. He is very high on the coyote. He believes that "now" you can install the coyote and all the trimmings for "close" to similar dollars spent for a crate motor with serpentine. I had trouble believing this but he was very direct and held fast to his position. He also pointed out that if you install a coyote you are getting a NEW engine and NOT a rebuilt motor. I won't detail his discussion and experience with using rebuilt crate motors but it was eye opening. He also mentioned that BC is working on a package called "coyote in a week" where if you bring your rolling chassis in they will install it for you in ONE week. Seems impossible to me but that was his position. Package not ready yet but soon. So,,,I am now leaning toward a coyote for reliability, additional resale value, and modernization plus taking advantage of the "in a week" package. Jason is hard to get on the phone but he/they will answer an email if you give them some time -- he is very busy. BTW he is also one brilliant technician. My head was swimming after our discussion!
So how much is the coyote package with all the trimmings? I really like the classic looked of the unstuffed engine compartment, and was thinking about a crate with fitech, but I hear you on the reliability and modern side.
doghows72
I'd be interested in the cost as well. I don't see how a coyote could even come close to a crate or rebuild swap?
I just did the explorer swap with the 4R trans and I don't think I'm into my whole package for more than $2500. Granted the motor has 40k on it but to save 10k on a coyote swap I think I'll stick to semi old school.
Rustytruck
I personally feel the Bronco platform is too unstable to utilize the full benefit of a coyote motor or I am just too damn old to push the peddle that far and hang on. I wish I had the willingness just to do a modern fuel injected 351W and if I want to go really wild maybe a fuel injected 300-6. I believe put the grunt where your going to use it. I wish Ford would have made the Bronco nose 3 inches longer. So I live with the stock 302 which will probably out live me.
AFLtCol
I started with a coyote conversion $$ which led to a frame-off restoration $$, which led to a lot of new parts being bolted on $$, which deserved a high dollar body prep/paint job $$$$$, which led to a new wheel/tire package $$ which prob will be changed out before I ever drive it $$, and getting ready to order all new interior $$ along with shinny stuff $$. So be careful how far you want to chase that rabbit down the money hole!
The only issue I'm hoping will be figured out is the coyote conversion requires a 2" body lift. Personally, I only want a 2 1/2 SL and also don't like a BL due to the body gap between the bumpers.
rye1678
I looked over the BC broncos page on the coyote conversion. Doesn't mention the need for coilovers, did engine fit with regular coils and shocks?
AFLtCol
Yes the coyote fits with only a slight modification to inner fender (trim, won't even notice) and a 2" body lift. Suspension wise, as far as I know, you can keep stock.
STalon89
If you want to run a coyote, do it. But do your research before it bleeds you dry. People will tell you explorer swap if money is tight, and Id agree. Plan on being close to 20k on a coyote build. Motor, atlas, and tranny you are already over 10k, and thats 3 items. Youll have to consider fuel, steering box, gears, rear end, axles, control pack, the list goes on and on. Just do your research before you dive in.
STalon89
Oh do I feel your pain. I bought a running driving bronco and next thing you know, I have a sandblasted tub.
DonaldDouchebag
I would like to look at photos of said completed Bronco on the internet.
in short, you should do it for me. Be a hero for somebody.
