commoncold
- Jan 15, 2008
- 256
The truck seems to be running rough... again. My mechanic showed me something with the distributor that I thought you guys might be able to answer.
The history:
351W
I just had the camshaft swapped last January
Original timing chain from when I bought the truck
Distributor is 3-4 year old stock replacement from NAPA
The distributor rotor turns a good 20 degrees back and forth when you turn it by hand (it doesn't seem like much resistance to wiggle it). The mechanic is saying a worn timing chain but another is saying something in the dizzy is loose.
Which is more likely and how do I check for it?
The history:
351W
