Tire Installation on Beadlock Wheels
ksagis
Aspiring Bronco Guru
Austin
I'm starting to think about getting some new wheels and likely going down the 17" diameter and thinking about getting a beadlock.
Was wondering if I'll be limited by what shops will install tires for me. i.e. will chain places like Discount Tire / AmericasTire / BigO install tires on bead lock wheels?
rcmbronc
Tomah WI
I doubt chain store will Mount bead locks. They are very easy to mount your self.
K
ksagis
Austin
Figured that might be the case, anybody have an idea if they would balance?
I am going to say you will be limited. Most of the techs doing tires only know the basics. I've seen the manager get involved when dealing with something as simple as a reversed drop center wheel (you mount the wheel upside down on the tire machine).
The thing with bead locks is you can mount them yourself. Breaking the inner bead is probably the hardest part, and that is pretty easy. All the bolts around the perimeter is just tedious. That is presuming you are running traditional bead locks. Icon has some new wheels that have traditional beads but bead locking bolts that are installed after the tire is seated https://www.methodracewheels.com/co...year=2021&make=Nissan&model=NV2500&event=load for reference. Those would still take a tire shop to mount.
There is also the Hutchinson wheel option, yet a different version of a beadlock.
Good chance they will balance, or at least try to. they may not even catch on that they are dealing with beadlocks. There are so many simulated beadlock looking wheels they will probably think it is one of those.
Gsxr7000
Mounting beadlocks are pretty easy. A little soapy water and a 5 gallon bucket you can do it yourself
Yeller
Rogers County Oklahoma
You don’t want the average tire monkey mounting your beadlocks, it is just asking for trouble. As for balancing, spending the time to make sure the tire is centered under the lock ring and they will balance fine, just follow the instructions for your wheel to the tee. Pay attention to maximum air pressures, DO NOT exceed it. I’ve only balanced my beadlock wheel/tire combo a couple of times but they did fine. I’ve not balanced the last 3 or 4 sets of tires on it bronco, they really have driven just fine, and I do run them on the street for very long distances on the interstate.
nvrstuk
PNW
As I was scrolling the answers Steve nailed it, DO NOT let any shop touch your bead locks.
They will NOT have the patience to do it correctly unless it is a 4wd specialty type shop. They will use impact wrenches to tighten the lock rings down probably in two stages instead of the multiple torque stages that bolts need to be tightened down properly. NOT a good idea at all. Like Steven mentioned ealier, air pressure is very important also. I see fb forum questions about guys running 32-35#'s in their tires on their Broncos or FJ's. Do that with beadlocks and you'll have some wild stories to share.
Also, unless you are actually wheeling your Bronco beadlocks are not needed. Yeah, it's probably a bragging rights thing I guess for a mall crawler Bronco but if you don't need them don't get them. Just more maintenance and possibilities of things to go wrong. Just my .02.
I have friends who have broken off 3 to 4 bolts out of the 24 that hold their lock rings on and the rest were loose as they were driving. These are guys who do maintenance regularly, just didn't catch it.
Liability is why most shops won't touch bead locks. Once they leave their shop they have no control over you retightening the lock ring bolts. How many people even retorqued their lug nuts after putting on snow tires/wheels?
Bolts are the ONLY thing that keeps the tire from coming off while driving down the freeway at 70mph. I've asked my buddies that run beadlocks and a couple of them have never checked the torque on the 24 or 32 bolts that hold the bead/lock ring on!! Never! Scary as heck
Anyway, I have no idea what you use your Bronco for and I'm not trying to insult in any way, shape or form but if you don't need them then don't get them.
Yeller
That you hope you get to share! Failures can be explosive if you’re in harms way. They are perfectly safe used properly. If you don’t wheel or don’t air down below 15 psi they are not necessary and do create added maintenance.
As for maintenance, routine torque checking, examine the rings for damage. If a ring is removed, replace the bolts. The bolts fatigue over time and replacing them is cheap insurance.
They also need to be matched to your tires. For example if the bead bundle is too thick the ring and wheel do not make metal to metal contact, which is important. That contact keeps the ring from squirming and flexing, fatiguing the bolts allowing them to work loose and/or break. Best case the tire goes flat, worst case is a rapid failure that results in a blow out and potential danger to anyone close.
nvrstuk
PNW
Right again Steve.
I use lock ring spacers with my 40" GY MTR's.
Without the spacers the beadlock rings actually become misshapen with a "cone" shape. Ksagis- Imagine a bolt going thru a pc of 1/2" plate at a 10degree angle. Then realize that the head of the bolt is not seated flat against the plate but only maybe 2 sides of the bolt head actually touch the plate. Hence, the heads pop off.
I bought internal BB's for balancing the next set of tires I mount up. See how they work. My first set of beadlocks with 37"s didn't balance well. I had them rebalanced several times but then I went with newer beadlocks and 40"s (after the first defective tire got replaced) they do fine up to 80+. I have noticed that as they wear I should probably rebalance them but I'm going to go with a different type of tire next summer instead. :)
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
X2 easy to mount the tires, only one side has to go thru. No machine needed. Soap and water the lip and drop the rim face that will get the lock ring in from the back side of the tire. Flip it over, use a block of 4X4 to raise the rim up enough to get the top bead to lay flat on the bead lock face. Make sense? Add balance beads, get to bolting.
Or put the rim (beadlock side face up) a little soapy water and drop the tire on top of the rim at an angle. Block of wood to raise it. And add some tire balance beads. Airsoft pellets work, and then start the process of lining up the bead lock rim bolt holes with the outer ring. Some time some longer bolts need to get you started. Anti-seize the bolts and use a torque wrench in a multi criss cross pattern.
All done, spray a little soapy water on the back side and put the air to it. CAUTION loud pops when the back bead seats. If you have a real wide tire and rim, use a cable come along run around the outside of the rim to compress the tire face and it will cause the side walls flex closer to the back bead.
STILL not working fill the leaky gap with grease. And hit the air. I do not recommend the ether pop seat trick.
nvrstuk
PNW
x2 on not using ether. We only use it if there's no other option on the trail in the WINTER only! Local buddy had the snow on fire for about a full minute all around his Bronco... imagine that in the woods/desert in the summer. Not smart but I've seen people do it.
Yeller
Great points Rich!
I have an old bar stool in the shop that has had hundreds of tire/wheels on it bolting the rings on. The key is getting the tire bead to sit flat on the face of the wheel. The better wheels have a small register lip to center the tire, take the time to tuck the edge of the bead around that lip, it ensures the tire is centered for a wobble free tire.
jamesroney
Fremont, CA
I guess I'm in trouble. I used an impact wrench to install mine, and I run 35 psi often. I can't seem to figure out how to mount a lock ring. If I add them, will I need to buy another torque wrench? I've never checked the torque on my bead locks. Ever.
I often use my Bronco to go to the shopping mall, and occasionally to the grocery store. Those little curb things in the parking lot are usually located in my way, and I often have to drive over them. If I had known I didn't need bead locks, I could have saved a ton of money. But everybody told me that my 5 lug pro-Rock 60's needed bead locks. Dang it...
Tee hee hee...
nvrstuk
PNW
Yup, you're in trouble buddy! Those curb cuts to the mall parking lot could blow those lock rings off and cause a nasty lawsuit.
I think if you add a snorkel to your rig tho you should be fine and it will finish out your build. Every lifted mall crawler needs a snorkel.
K
ksagis
Austin
Yes, it's very likely for how I wheel/drive that I don't need beadlocks so why deal with them, that's totally fair and good input. Why was I looking at this particular wheel that happened to be beadlocks? Truth is I'm struggling to find wheels in 17s and a backspace I need to clear inner fenders when stuffed. Given it's $4k on wheels and tires, want to be sure it's something I really love. After looking around quite a lot, I came across some wheels with specs I liked that happened to be beadlocks and started thinking about them. Is maintenance on them more than a traditional wheel, sure. Is it more of a pain than the rest of the stuff on my rig? Probably not. Going around the wheels once every 1000 miles with torque wrench is not a big deal to me.
If anybody can point me at nice looking a 17 inch diameter wheel, hopefully 9" wide, and 4" of backspace or less, I'd really appreciate it. Most everything I can find in Methods, Fuels, Racelines, etc are more than 4" of BS.
Hope everybody had a good Turkey Day break.
nvrstuk
PNW
Raceline can build you just about any wheel with the backspacing you want for not that much more $.
Call and ask.
I had some built and the price was quite a bit less than many of their non custom wheels.
These
Are 4.25" BS on 17" Monsters
