I did some more on the AC/Heat. The unit was mounted to the fire wall and on top of the bracket I made for more support.
After the unit was mounted I ran the hoses under the dash. They are tight but it all worked out.
With the lines done under the dash I decided to go back under the hood. This is when the fun started, NOT.
I was planning on using a electric fan because I can't stand the sound of a direct drive fan. The fan I picked had a high CFM rating and it was 3.0 inches thick. That seemed fine until I found I had 2.9 inches of room. You all know the saying "one modification leads to another" it is so true.
I found a Haden clutch #2765 and fan #3618 that looks like it will work, with some help. The clutch cleared the radiator by .400 on a inch.
However the fan hit the AC Compressor.
The only thing I could see to do was move the AC Compressor back and use the front belt groove. I modified the bracket so it went back and up a little to clear the valve cover.
Now the fan clears by about .300 of a inch.
The clutch was a real pain mounting it to the water pump with bolts so I went with studs.
Next came the shroud. It cleared the fan after I made a new lower mount. I had to drop it some to make up for the 1" body lift that was done to clear the 5 speed. Even with the compressor moved back it still hit the shroud.
I notched the side for the compressor and I had to do the bottom to clear the clutch when installing it. The shroud would not fit between the clutch and the radiator.
I knew the belt would be short after raising the compressor about .500 of a inch. No problem I thought I will get the next one bigger. Not so easy. The next Gates number was not big enough and the one after that was too big. I need a size in between. After looking at it I decided to modify the Power Steering adjusting bracket so it can travel a little further and I can run the bigger belt.
I did however pick up the painted tire carrier and it looks great.
Nick did a fantastic job blending in all of my welds.
Well I am done for now. I will post more pictures when I get them.
Thanks... Tom
