Anybody run one of these?
I have one available to me for pretty cheap and just wondering if its worth my time.
Normally a Torker intake is a higher rpm manifold not really suited for a Bronco. Especially if you have a poor gearing/tire match.
But a good price is a good price, up to a point. Not as tall as some high rpm setups, but might also be trouble if you don't have a body lift.
Might be better than what you have, but most likely it's a pass.
I've been having a hell of a time getting my current setup to run properly. It runs great in first gear, (3 speed on the floor), but as soon as i put it in second and let out the clutch, the rpm's drop way down and I have no power uphill or with any kind of load.
Sounds typical of a Bronco with larger tires and 3.50 gears.
Do you know what you have in the gearing department now? What size tires?
...and I can't tell if i have a vacuum leak.
Have you tried the old spray method? It's very easy to find vacuum leaks usually, with just a can of carb cleaner or similar product. Even WD-40 or water in a spray bottle will often get the job done.
(edit: obviously you do know about that and have done it!)
Don't have any marks left on my balancer either other than TDC, so I can set my timing roughly, mostly by ear. Any insight?
As Amac said, a timing-tape kit would be the best way. But you can also just make your own marks. You can base them off of what others have here I would think. Someone can give you an idea of how far apart 2 or 5 degree tick marks should be. Or you can buy a "dial back" timing light so you don't need anything more than the zero mark.
Since you don't have any other marks, are you advancing your timing by turning the distributor clockwise? And your light is moving to the right of the zero mark, correct?
Just as a guess, I'd say that half an inch to the right of the zero mark is somewhere around 6 degrees or so. That's just from memory though. Doing the actual math it looks like for a 7" diameter damper, roughly every 1/8" around the edge is equal 2 degrees. Hmm, that makes 1/2" 6 degrees like I said!
Saying it that way though (1/8" = 2°) sounds like a big gap for 2 degrees.
Anyway, you get the idear. Easy enough to make something work in this case. Especially since knowing what you have down to the nth-degree is not necessary to just get it running well.
