Towing with an EB
mortimersnerd
The wife and I have talked about getting a small, cheap tent trailer. Both of our families had them when we were growing up and they were a great way to get away. How well would a Bronco pull one? More importantly, how would a built EB on 37's and a mild wheelbase stretch pull one? If we pick one up, I'd consider a small lift to make getting it out to dispersed camping sites easier.
On the same note, what's the max reasonable load an EB can tow? I also need to rent a small excavator, but have assumed that the 7500lb combined weight was too high for a Bronco, even for the 5 mile drive from Home Depot to my home.
DJs74
I think you'll be fine towing a "pop-up" type trailer but would not recommend a large "travel-trailer"
As long as your suspension and handling are stable without a trailer, you should be OK with the small camping trailer.
My dad's friend had a pop up and towed it with his '73 Bronco in the mid 70s... him, his wife, my mom & dad and me all took a trip together in it one summer (even with a 2 seater bicycle) and no problems.
As long as your tow vehicle is the boss (weight-wise), all should be fine
DJs74
AaronWelch
Atascocita, TX.
Yea I have seen the small Airstream type trailers towed with no issues so you should be good to go with a smaller popup type trailer.
Aaron
Toddpole
My neighbor built a small teardrop trailer. It's the perfect size and vintage look for an EB. You can find plans on the internet. Not as much stand up room as a pop up though.
blubuckaroo
Grease Monkey
Ridgefield WA
I wouldn't have bought it if it wouldn't tow...
Hank_
I am restoring a 1986 Coleman Colorado. I will be pulling it with my bronco. Here are a couple pics. It should be all finished in about a week.
IMG_20150524_132605053_zpsd8xr5elr.jpg~original
Before disassembly.
IMG_20150530_142158991_zpszqjffeu5.jpg~original
Installed a receiver for a bike rack and installed larger tires.
IMG_20150623_194649594_HDR_zpsqu1vuidt.jpg~original
All new floor and vinyl. Walls were stripped to the aluminum sheet and all new wood and foam installed.
IMG_20150623_213509912_zpsi1unglnl.jpg~original
Ditched the aluminum corner brackets and welded up some heavy duty steel brackets. The previous owners had hit something at one time and dented up the aluminum ones which offered almost no protection.
Hank
jw0747
San Antonio, TX
Before you buy go rent a U-Haul enclosed trailer to tow around for a day or so. Fill it with a bunch of sandbags or similar stuff to add weight to simulate towing a camping trailer. That'll answer your question before jumping in.
jpw
back in the day, Broncos were a work"horse". big dumb loads were the rule not the exception for some of us(can post pics later if there is interest). my 72 has pulled everything from a willys trailer with 3000 pounds of gravel in it to a 66 passenger bus from behind a building so that the tow truck could get to it. Here in the Islands there's not much freeway driving so you can take your time with a heavy load. I don't have what it takes to hook up to those kinds of loads anymore:)
All of the advice you got so far is great especially testing it out with the rental. if your speeds are kept low and you are cautious it can get the job done some pretty big loads. Stopping/ steering the load is usually a bigger concern then moving it.
J
DuctTape
Bozeman, MT
One of the many reasons I love this site. So many times someone has a simple, cheap, smart solution.
bronconut73
I have put over 2 thousand miles on my eb pulling my bass boat all over the Damn place in the last 4 months.
It has been such a champ.
Never ever felt odd. I almost forget it's there. Just awesome.
I just wanted to use it to get the boat home but have since pulled the boat everywhere with it.
Pulls better than I ever thought.
blubuckaroo
Grease Monkey
Ridgefield WA
We tow with it a lot so I've got a few recommendations...
- Adjust the load for plenty of tongue weight.
- Have a hitch height that keeps the trailer slightly lower in the front.
- Good trailer brakes.
- Reasonable speed.
In my experience, our car has plenty of power. Short wheelbase and too much tire/suspension is the downside. As long as you adjust for it and keep your speed moderate, you'll do fine.
EricLar80
You are braver than me pulling that concrete trailer. I considered pulling a yard of concrete using one of those bucket trailers, but they run like 3500 lbs fully loaded. I have good brakes and I cannot imagine an emergency stop with that top heavy load.
I have gotten a yard or so of gravel, and a couple large trees, using my utility trailer. I felt comfortable with it.
Eric
sprint289
Darlington, S.C.
Trailer towing
Towed 20ft camper in smoky mountains for 7 summers with a 74 Bronco with auto. Had electric brakes and equalize bars. Never had a problem, but i was a lot younger then.
blubuckaroo
Grease Monkey
Ridgefield WA
Eric
Well of coarse you need to apply some common sense. With a load of cement, you're not going to be traveling down the freeway. And the cement mixer was equipped with surge brakes.;)
tatersalad
My pop pulled a 21 ft travel trailer all over California when I was a kid. He had a load leveling hitch, trailer brakes were a must in the early ones. They weren't lifted back then though.
