77 Bronco D44 axle with BCB Tie Rod Over linkage. The tie rod hits the track bar stud at axle, and limits right turns.
I purchased a track bar riser bracket made from 1/4” plate.
When riser is bolted to bracket on axle there is a 3/16” gap between riser and axle tube.
The vendor alluded to filling the gap when welding, but this is excessive, for my welding skills.
Should I:
1) Leave the gap, and find a Welder with better skills than me?
2) Try to close the gap by heating and beating the riser?
3) Add some 3/16 plate or bar to fill gap?
4) See if a WH bracket (3/8 plate) fits better?
5) Leave stock, and avoid right turns into parking spots.
Should I:
