the bar level means that you have the weight distributed equally front and rear and that the load is centered over the axles of the trailer.......get it to far back and it will look like your trying to swat flys with your trailer...lol
u dont even have to register a trailer here in OK unless you just want to
Why is the beaver tail so important?
I prefer to use unsprung points for attachment. This prevents suspension movement from allowing the tie-downs to loosen or fall off. There are tie-downs that go over the tires themselves... I have custom straps made with hardened chain at the end, attached to a ring that the strap is then sewn through. Allows ratchet strap use but provides a strong loop that won't get cut if there is a sharp edge on an A-arm, for example.
If you have time and don't mind a drive, I'd seriously look into buying OUT of CA! Look in Phoenix you'll save close to a grand doing it that way! I bought an 18' PJ for $2700 last year and I would highly recommend them. They are powder coated not just spray painted like most of the east Texas trailers I looked at (most of those were bare steel under the wood!). AZ always has good deals on car haulers on craigslist. Try Yuma even?
Wait until your close to moving, buy out of state (avoid CA sales tax), get a temp tag for $30 then permenantly register in OK for probably dirt cheap.
