Trailer size and bronco weight.
KyleQ
Can we agree that it is "trailer" and not "trailor"?
Right now I have a 7k, 18' with electrics on one. I will build a 20' 10k with brakes on both eventually. It just takes time and money.
I have built maybe 30 of these things over the years and everybody forgets the tie downs. Go to a truck shop (not the pick up store...) and buy some real D rings. Weld those things on the corners and you will never be sorry for spending that $40.
No kidding - I LOVE the d-rings on my trailer. They are stamped 10,000 on mine and I cringe every time I see people tieing shit down from the stake pockets sideways - no way would I trust those to hold a load when I need it to.
KyleQ
"Some operators like to cross the rear tie downs. This is acceptable but you must use caution. Make sure that the attachment point you use on the vehicle will not be able to slide towards the center of the vehicle. For example, if you use J-hooks attached to a rear axle housing and you cross your chains, the J-hook may be able to slide towards the center and cause your tie downs to loosen. I prefer not to cross my tie downs. If you have your tie-downs crossed and one side breaks or becomes disconnected, the other side may tend to pull the vehicle to that side of the deck. If the tie downs are straight to the rear of the deck and one side breaks or becomes disconnected, the other tie down still pulls straight back and not to the opposite side."
It doesn't say not to, it's just what he likes to do. I don't see a vehicle, espically the weight of an EB, sliding sideways on a wooden deck trailer. The front axle is easy to strap, the rear axle I now hook my axle straps on the outsides of my spring perches - nothing can slide side to side.
fuzzy2133
San Jose, CA
Correct it is not wrong to cross tie downs. My concern is just getting word out if someone runs across a officer and you are told it is not acceptable to cross them it does not catch you out of the blue.
